Results 1 to 5 of 5
Thread: EML Sidecar parts and such
    The Big Red One sgtbill's Avatar
    Jul 2006
    Columbus, IN
    Hello all: I have a K100RS with and EML GT2 sidecar. I need help finding a source for a couple of obscure parts. The sidecar rig is mounted to a frame and there are rubber isolators both fore and aft between the sidecar (fiberglass) and the frame (tubular steel). These are rubber grommets without threading in the center. My rig has lost two of the rubber grommets (or perhaps bushings) this summer and I am looking for a source for them. I have seen the article on EML sidecar vibration here: http://home.jtan.com/~joe/vibes.htm
    When I google the parts listed in the above article, I find only factory availability and nothing for buying only 5 or 10 copies. Anyone know where I can source the rubber isolators. As long as I'll have the rig undone I would like to replace ann 5. I even have a friend with the same sidecar outfit and I'm sure he will need them as well.
    Any thoughts?
    sgtbill
    Duty First!
    86 K100RS EML & 79 R100S
    2007 F800ST & 2014 F800GS & 2014 F700GS
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    Bill, if you are talking about the dampeners for the body, mine has some retrofitted/added from a Ural.
    I'd be very interested in hearing an answer as to where to get parts also.
    (such as brake pads)
    Ken
    -Albert Eienstein
    Oct 2006
    For sidecar wheel brake pads I took one of the old ones to the local Honda/Suzuki/ Kawasaki/Yamaha dealer and they managed to match it. One of the aftermarket parts catalogs had full size drawings of the pads. I think is was Ducati rear pads.
    I'm now running 2 Suzuki GSXR rear calipers on the sidecar, one hooked to the front brake, one to the back.
    I've had rotten luck finding EML parts since BMW in ST Louis quit as the EML importer. Pretty much everything on my rig has been upgraded/modified.
    Mike
    Mike Currin
    93 K1100RS / EML Speed 2000 sidecar
    89 Honda GB 500
    67 Triumph 650 Chopper
    Sep 2009
    SW, MO
    Mike, thanks for that!
    Ken
    -Albert Eienstein
    Apr 2005
    Rapid City South Dakota
    Using the same method as Ken I found EBC FA-47 brake pads fit my 1989 GT2 sidecar brake. EML used several brakes but mine used a Brembo that was a mini of the brakes on my 85 K100. Harold in Kansas
    Harold In Kansas
    1985 K100RT Bullit
    1985 K100XX/EML Bemel
