Results 1 to 15 of 16
Thread: stripped allen head
    Apr 2008
    Waikoloa, Hawaii
    stripped allen head
    96 R1100RT
    While trying to remove one of the two allen head bolt holding on my rear brake rotor, after heating extensively with heat gun, propane torch and acetylene torch and still not being able to remove the bolt the allen head stripped . the other side came out with no heat at all? So now I have to drill it out or leave the same rotor on the bike. It looks like the 4 bolts that hold the wheel on would keep the rotor in place without any bolts. Anyone have any ideas? Thanks Woody
    Mansfield,MA
    Quote Originally Posted by woody99 View Post
    96 R1100RT
    Always easier with a picture but I will have to guess the part where the Allen head fits into stripped out? I frequently drop a nut over it and weld in the center so I can grab it again. I have also chiseled them around in a circular pattern but that's a bit iffy.
    Mod Squad
    2009 F800GS 1994 TW200
    Apr 2006
    take a next sized up torx bit and use a hammer to drive it in and form a new socket. This has never failed me.
    2010 F800GS Full Ohlins package, '04 R1100S Replika
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Tuscany and Central Italy 2010
    Retired from riding rad's Avatar
    Santa Cruz
    Quote Originally Posted by pffog View Post
    Do this and try no heat. Any low level thread locker was cooked with all that heating you did before, now you are just expanding the fastener.
    Mar 2013
    Winnipeg, MB, Canada
    Yep, great advice.
    Any/all of the comments give you a simple solution.
    3xR90/6, two just sold, one for a sidecar.
    1983 K100RS for winter project, two K's sold and just acquired a very rough R80RT.
    Don't know if this is applicable but it is not uncommon for a weldor to place a hex nut over a stuck fastener and plug weld it on. In addition to having a nice new hex head the heat also helps. In not as good of a welder as some so I weld a heavy flat washer on first then a nut.
    Good luck
    Registered User rxcrider's Avatar
    Aug 2010
    North Ridgeville OH
    I'm also a fan of the welding technique. I will usually try a next size standard bit or torx bit first, but the welding trick rarely fails. Sometimes it takes multiple attempts. The washer trick can help as it will shield some of the surrounding steel. Sometimes I just take a a piece of flat stock and weld it straight to the bolt, using the flat stock as the wrench handle.
    Those allen recesses are very shallow and BMW uses high strength thread locker at the factory. I have had good luck with heat from a pencil torch right in the center of the recess followed by using a torx bit driven into the recess. I would re-use heat again, but not a lot, because the threadlocker can reset after it has melted.
    Feb 2005
    Trinity, NC
    Woody, those screws are specified as one-time use. The heads are shallow and they are easy to strip. You are right; on the R1100RT, the wheel lugs will hold the rotor tight - those two screws are really just there to hold the rotor in place. The thread locker on those screws is overdone. Get the stripped one out any way you can (lots of good advice already given) and then get a new screw to replace it.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Quote Originally Posted by m_stock10506 View Post
    +1
    Apr 2008
    Waikoloa, Hawaii
    Thanks for all the great advice Woody
    Apr 2008
    Waikoloa, Hawaii
    stripped allen head
    I did the torx bit and it worked well after pounding it with a hammer several hard blows. thanks Woody
    Mansfield,MA
    Mod Squad
    Apr 2006
    Sounds like you are at 100% success rate too. Glad you were successful, sure beats the other choices.
    Apr 2012
    Los Angeles, CA
    Nice thread, I just had to bolt mine all back together with the old rotor still on there after having the same problem. I'll try the heat+torx technique, and maybe scrape some of the threadlocker off the new screws for good measure. (They're 86 cents at the dealer, by the way.)
    On a side note, for the "slip a bolt over it and weld" advice -- these screws are flat-head, countersunk into the rotor carrier. Nothing to slip over, unless you drill the heads off and remove the rotor.
    2000 R1100RT / 1987 K75C (RIP) / Santa Clarita, CA
