Results 1 to 9 of 9
Thread: Brown side stand install info
    Registered User donmitt's Avatar
    Mar 2006
    Bellville, TX
    I have searched as best I can for information about using an engine guard (frame) clamp for the front mount of the brown side stand that I have seen on here before but now that I need that information, I can't find it. Does any one remember this or is it just another one of my old man hallucinations. Thanks for any help anyone can provide.
    Don Mitchell
    Don Mitchell
    Vancouver, B.C. Canada
    I think I posted it some time ago but I can't find it either.
    Oh well, here is what it looks like installed.
    Order these two parts from Motobins in the UK.
    95631 lower half kinked black clamp for twins
    95633 lower half u shaped black clamp for twins
    You'll need a bolt, nut and lock washer as well.
    I used a longer bolt and a spacer between the Brown stand (with exhaust pipe strap) and the GS frame bracket to better align everything. These clamps are also the hot tip for mounting /7 style dual horns on an earlier bike that had only the central horn mount.
    The only place that I know that has info on the various side stands is Snowbum's site:
    http://bmwmotorcycletech.info/FarleyBrownSurefoot.htm
    Mar 2006
    Bellville, TX
    Thanks Happy,
    That's what I was looking for. I had wrote the part # down so that I could go get them but time passed till I wanted to do the job and then I couldn't find your post to see just how it worked for you.
    Also I thank you other folks that took the time to answer my question.
    Don
    Don Mitchell
    Monza Blue 1974 R90/6
    Delaware
    Quote Originally Posted by barron_williams View Post
    Hey you found it! Even had links to the part pictures.
    I really like this solution. It's not expensive, easy to install, parts are already painted and solves all the issues.
    Delaware
    Yes. Good solution. I made mine out of a piece of 1" steel from Home Depot. Wasn't hard to drill the holes. I didn't use a longer threaded rod, I just backed off the right side nut a few turns to give me the additional length on the left side. Sprayed it with black semi gloss rustoleum before install. Only thing is that pictures show faired bike so metal bar installs straight. On my /6, the front mounting bolt is not aligned with the rear, so you have to bend the bar slightly. Hard to explain, but easy to see if you are using this mod for a Brown on the older bikes.
    Regards,
    Barron
    P.S. For Kurt, this thread is a good compilation of Brown install tips.
    I did include the above thread link the list of Resources and Links.
