Results 1 to 15 of 19
Thread: Brake Bleed Question '03 R1100S
    Left Coast Rider
    Nov 2011
    I've got both the ABS and servo system on this bike and its time to bleed the brakes.
    If I were to install SpeedBleeders, would I then be able to simply squeeze the brake lever (while ensuring the reservoir is kept adequately filled) and evacuate the old fluid as I would any standard-type brake system?
    Your knowledge and experienced input is appreciated.
    Nov 2007
    no no no NO NO, STOP NOW!
    You have 4 brake reservoirs. FOUR
    here are the instructions
    http://advwisdom.hogranch.com/Wisdom/service_abs3.pdf
    17 pages in great detail. If you do not want to follow them then take to a dealer or get help
    Rod
    motorcycle cowboy Tennessean's Avatar
    Oct 2005
    East Tennessee
    I installed Speed Bleeders on my '04 1150 RT brake calipers. I have read of some who wanted to put Speed Bleeders on the ABS unit but I would advise against that out of fear of damage to the ABS unit itself.
    2013 Goldwing
    Nov 2007
    speed bleeders on the calipers I do not feel do any good. Since it is power, fill the funnel, put on a clear hose. Pull or push on the lever or petal, crack the bleeder, watch the fluid in the funnel. When funnel just empty, close bleeder. Repeat as needed. Speed bleeder gains very little. Now on 3 fittings on the ABS, if you are brave, then they fain something. Nothing about this is hard, just a little fiddly.
    Rod
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by ragtoplvr View Post
    Ok, just want to be clear here. You seem to be saying that I shouldn't do this?
    Message received, loud and clear.
    Nov 2007
    If you run the internal reservoirs dry on the abs unit you can not ride until it is refilled. They are under the tank in the abs unit. I suppose, not planning to find out, that running it dry is not a good idea. With the right tools, bleeding is easy, a few steps but easy,
    Rod
    Oct 2005
    East Tennessee
    Rod
    With a speed bleeder, you don't have to open and close the bleed screw each time you open and close the lever or petal.
    2013 Goldwing
    Apr 2006
    Quote Originally Posted by 2bikemike View Post
    On the servo ABS they are useless, to flush/bleed the caliper circuits you use the funnel at the ABS unit basically just to expand the reservoir capacity and make it easy to see. With the key on pressing the lever engages the pump and when you open the bleeder fluid will flow in a continuous stream, YOU DO NOT PUMP IT!
    Now for the lever circuits, yes you pump the levers if you do not have a vacuum bleeder.
    That said a vacuum bleeder is simple and cheap to make take any stiff vessel, a glass mayonnaise or pickle jar will work ( I actually have a piece of ABS pipe with caps glued on)
    Take the Jar and go buy some 1/4" vinyl tubing at the hardware store. Drill a couple holes in the cover and insert the tube, the inlet will extend toward the bottom of the jar. The vacuum side will just go into the cover. Next seal them up with some silicone calking and let it cure. (you can also use bigger hose for the vacuum source)
    To use it, any vacuum source will work, even a vacuum cleaner (not as good as other sources), I now have a vacuum pump, but my other favorite source is just pull any vacuum line off the car/bike intake and start the engine, connect the other line (jar inlet) inlet to the bleeder and open it up and you no longer have to pump the lever. To use a vacuum cleaner you just need some duct tape to seal the big and little lines.
    2010 F800GS Full Ohlins package, '04 R1100S Replika
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Tuscany and Central Italy 2010
    Oct 2005
    East Tennessee
    Quote Originally Posted by pffog View Post
    So, I've been doing it wrong all these years. Thanks for taking the time to explain.
    2013 Goldwing
    Nov 2007
    I agree that with the servo pump speed bleeders on the calipers do not seem to help much. I can easily shut the bleeder while keeping the pump running. On the ABS unit, they could be a good deal, and a speed bleeder on the clutch is very useful. I use my mityvac to catch the fluid. Rod
    Aspiring Profligate Jeff488's Avatar
    Apr 2007
    Nacogdoches, TX
    I got a brake bleeding checklist by Dana Hager for these abs systems from somewhere and he's OK with me sharing it.
    It's surely helped me doing this procedure, as I can't remember what the proper sequence is.
    Just email me and I'll send it out.
    It's about 1.3 megs, so your server may not take it. Can't hurt to try, though.
    '08 BMW R1200RT
    '75 Red R75/6
    '08 Suzuki DL650 "Screaming Yellow Zonker"
    Looking for Ed Sanders' Truck Stop.
    Left Coast Rider
    Nov 2011
    Thanks for everyone's responses. Having created brake fluid rain showers before (and paid the price for it ) I think I'll leave this to my trusty mechanic.
    Retired from riding rad's Avatar
    Santa Cruz
    Quote Originally Posted by BC1100S View Post
    Whata wuss....You Oil Head guys.....
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by rad View Post
    What are YOU doing here? Aren't you a square head, I mean, hex head? Come back for some love and entertainment?
    Registered User SeabeckS's Avatar
    Oct 2005
    GPS (Greater Puget Sound)
    Darn! I thought after you had mastered this maintenance task, you could come down to the Hood Canal and do mine. Guess I'll have to go to my backup plan!
    Cheers!
    PS. I woulda bought you a beer, heck, maybe even two!
    Bill Johnston
