Results 1 to 15 of 17
Thread: 2000 R11RT-P What does this do?
    Doing a battery replacement. On removing the left side Tupperware, I note this hose, coming from under the battery cradle, just laying on top of a wire bundle, running towards the forward portion of the bike, with its end not connected to anything. The open end, a 90 degree formed elbow, does not look like it has ever been connected to anything. What does this do/what is it for and should it be connected somewhere?
    Gear Up and Ride Safe
    Jim Rogers
    2010 R12GSA aka Heidi
    Yorktown, Va
    Left Coast Rider
    Nov 2011
    It could be the hood release....but its more likely the vent hose for your battery.
    Still a learning newbie !
    Mar 2012
    New Orleans Louisana
    My vote is hood release. Or the windshield wiper washer hose?
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by Dadrider View Post
    Front or rear?
    Hang on, this is an ex-police bike? Could be a catheter connection.
    OK, I'll quit with the jokes. This is serious business...
    Nope - the hood release is under the dash by the left heater vent control and the washer reservoir/pump/hoses are on the other side, just behind the pull off cover.
    Jim Rogers
    Yorktown, Va
    Mar 2007
    Ambler, PA
    This is a vent hose for a lead-acid battery.
    It is not needed if your replacement battery is Gel or AGM, the current standard I believe.
    Doug Raymond,
    R1150RT '02, R1200GSA '11
    Mar 2013
    Winnipeg, MB, Canada
    Quote Originally Posted by DougRaymond View Post
    I think that's the right answer but the catheter response was pretty damn funny. You never see the good boys with the yellow stripes on their pants (RCMP, in Canada) taking a "break" on the side of the road.
    3xR90/6, two just sold, one for a sidecar.
    1983 K100RS for winter project, two K's sold and just acquired a very rough R80RT.
    We have a winner. It IS the vent from the original wet battery. Before pulling out the old PC680, I noted the 'L' was the perfect length to connect to a vented battery. On pulling the old battery, I was able to see the hose and follow it to the bitter end, which was along with other similar drain hoses. Mystery solved, unused hose removed.
    Jim Rogers
    Yorktown, Va
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    That's the battery pressurizer. You have to blow into it before starting; if you're drunk, the battery then becomes inebriated and thereby prevents starting. The newer versions have a Bosch voice chip that reminds you to put the kickstand down before getting off the bike.
    (But BC's answer WAS better!)
    Well, battery replaced with no issue. Right side body panel went on with ease. The left side panel, another story. Just can't seem to get the holes (3) on the tank to line up. Looking closely, the holes on the tank cowling are the issue. HMMM Will get back to it tomorrow.
    Jim Rogers
    Yorktown, Va
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Yes, you are 100% correct.
    It is not a Texas Catheter
    Ufda happens..........
    Aug 2006
    Scranton, Pa.
    What does this do?
    You guys are all wrong!!!!!
    The bike was obviously owned by a proctologist and this hose with adapter is used for performing enemas on left handed people!
    Aug 2006
    Scranton, Pa.
    What does this do?
    Don't you guys know anything??
    GEEZER lsouth3's Avatar
    Oct 2005
    East Texas
    hose
    Nothing at all to add but THANKS to one and all for the morning giggles.
    Well Done!
    Lee - The older I get the better I was
    1994 R1100RSL, Black. 1994 R1100RSL, Silver Pearl and a "new" 2001 R1100RS, Red!
    Treat all others with politeness. Not because they are nice but because you are.
    Thread Close Out
    Regarding the body panels, took the right side off and started over. Put both panels in place and then started with the tank screws. All went on well. 6, 2, and Even, Over and Out.
    Jim Rogers
    Yorktown, Va
