Results 1 to 15 of 18
Thread: Blown Apart
    Blown Apart
    In the middle of a 500 miles trip to get home, engine let go.
    MSF Rider Coach
    Total Control Instructor
    2007 BMW K1200GT, 2005 KTM 950 Adventure, 2005 Yamaha Vmax, 2005 SV650S, 1991 Honda VFR750, 2004 Honda CRF250X
    Feb 2007
    Very sorry - that is going to be expensive.
    What were the signs leading up to the rod coming apart? Did you get a low oil pressure light? Anything?
    Quote Originally Posted by limecreek View Post
    Engine had a noise, I thought it was bad, Had it to Heids, they thought it was crank related, and Max's Thought it was a rod, but it went to a dealer in N.C. who said it was the cam chain tensioner and they replaced it. Still had the noise, they claimed it was nothing and to ride it. So I did, needless to say Paul and Heids was right again! And I had to get towed off of interstea 70 in Ohio and then have someone drive five hours from maryland with my truck to get me. Then we droove back to maryland and I had to drive to New York to get home.
    MSF Rider Coach
    Dec 2010
    Quote Originally Posted by outlaws Justice View Post
    Ouch!! What motorcycle / engine was that?
    Quote Originally Posted by 71243 View Post
    ouch!! what motorcycle / engine was that?
    2007 k1200gt
    MSF Rider Coach
    Nov 2005
    Lancaster County, PA
    Hmmm, think I'd send it back to the dealer in NC, see what they think now.....
    Quote Originally Posted by john1691 View Post
    It is headed back there on saturday
    MSF Rider Coach
    Wilmington, NC
    Asheville, Raleigh or Greensboro?
    Did your bike have the unstable idle accompanied by chain rattle periodically?
    can tell you that bike retroed with the new tensioner and jumped guard will still do that- I suspect it caused in part by a stretched chain from being banged around prior.
    Anyway, that type of functioning can't be any good at all for rods- pretty much like hammering them.
    Apparenyl 5-50 is now the recommended oil weight- to me it exacerbates the chain issues with thse bikes rather than helping but it might flow better if there are fundamental lube issues at the rods.
    Dec 2005
    5w 50.... really???
    5w 50?
    I'm down.
    I was considering running 10w 50 in order to help with gear changes.
    The only time that my 2008 GT trans shifts nicely is when the oil is stone cold.
    Maybe a few times through the gears... a couple minutes....
    Who makes a 5w 50?
    I'll try it.
    For the OP with the blown engine... ughhh, I feel your pain.
    This is my second '08 GT.
    Didn't feel confident about the first.
    Don't know why I bought the second. Twas a good deal I guess.
    I don't exactly get a warm and fuzzy from these machines.
    d'milan
    #13338 PGlaves's Avatar
    This could make for some very interesting conversation, I'd guess.
    Rally Rat Roc-Roc's Avatar
    Jun 2004
    Indiana
    ROC-ROC
    President of the Hoosier Beemers
    BMW MOA Ambassador
    Knights of the Roundel
    I dont know about chain noise a the noise heard is described above. I was having the engine take a few seconds to idel down the day this happened. Also the cam chain had been inspected prior to this trip and I was "told" it was in spec and good to go.
    MSF Rider Coach
    Helen's '05 K12S sounded like marbles bouncing in the valve cover at first start...at 36K I changed the cam chain & sprocket even though I had done the tensioner/guard prior. The chain and sprocket are now a recommended service bulletin item at 36K I recall.
    We bought this bike with 27K and it was noisy from day one...this was before the tensioner upgrade came out.
    Seems like Rick Mayer had a engine failure also on a S a few years back...and know of one other CENTEX female rider (Muddy1) who lost a top end due to broken chain I believe.
    The oil weight change was more due to the extremely annoying chirping/judder clutch issue at idle on the early Wedge engines...also an expensive retro including better clutch basket (riveted in!!) and wet plates...It's annoying on Helen's...but my 05 has not showed symptoms at 26K . The lighter weight really doesn't help her clutch noise. Of course BMW sells the weight now. Some folks run Castrol.
    Sorry for the ugly looking issue , that def sucks!
    Steve Henson
    Wilmington, NC
    Meant to say 5-40! Sorry for the typo and failure to catch it.
    Do you know for sure this bike was never dumped and left running for a while on its side, resulting in no oil pressure? Don' think it has any kind of tipover but never went over the wiring diagram to confirm. On a bike that already has a wonky cam drive, that would probably do it in easily- already hammered rod ends with no pressure created wiped bearing quickly- with complete destruct at a later date.
    Dec 2005
    Nuts
    Ya got me all worked up.
    I'm gonna try it anyway.
    Not 5W 50, don't think that can be found. But maybe my own witch's brew.
    2 qts 5W-40 4T and 2 quarts 10W-50 4T = 7.5W-45
    Or maybe I'll just try straight 10W-50 4T.
    I don't ride much when it's under 40 degrees outside, and when it is cold out, I'll let it warm up a bit b-4 putting any load on it.
    Regarding Blown Apart
    Just a rumor I suppose, but I spoke with a gent at a certain used motorcycle part supplier, that may or may not specialize in any particular brand , that said they have seen a noticeable and steady increase in folks searching for K12 engines due to bottom end failure.
    d'milan
