Results 16 to 20 of 20
Thread: Fuel Level Sending Unit Confusion
    My fuel sending unit ('04 R1150RT) is this float that moves the rheostat.
    What/Where is this tube that was mentioned?
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Quote Originally Posted by texasmule View Post
    That is just for the lo fuel light on the RT's.
    The sender is further down the Fiche.
    http://www.maxbmwmotorcycles.com/fic...png?v=04302013
    Ufda happens..........
    this is for the RID fuel level on the right top of tank... on the RT. That connector pigtail plugs into fuel pump plate
    Steve Henson
    I learned something new today, today wasn't a total waste...
    Thanks guys. I'll check mine. My fuel gauge never reaches "full" any longer. Fill gas to the top, and
    it still shows two bars down. A mild irritant, as I always use the trip odo as my fuel gauge.
    Dec 2004
    Arkansas
    For what it's worth, I seem to fixed my RID gauge problem. I disconnected the main fuel tank plug and cleaned it up with contact cleaner then applied dielectric grease. This seemed to help a little. I then added Techron to the fuel tank and refilled it. I put 1/2 a bottle in, 8 oz. After running about 178 miles everything seems to working properly. It is also running a bit better.
    Rod
