Results 1 to 6 of 6
Thread: powering heated gear from a megaboost battery-tender SAE plug?
    Registered User ezwicky's Avatar
    Oct 2012
    hi all,
    i use a megaboost battery tender which uses an SAE harness connected to the + and - battery terminals. is there a line of heated clothing that uses this same connection? i'd like to *not* need to connect another set of wires to the battery terminals... it's already getting crowded in that vicinity.
    thanks in advance,
    -eric
    BMWMOA #182796
    '76 R90/6
    #13338 PGlaves's Avatar
    Oct 2003
    "Big Bend" TX
    Quote Originally Posted by ezwicky View Post
    hi all,
    thanks in advance,
    -eric
    I don't think so - any more - the coaxial just work better. But Warm and Safe and Powerlet both have adaptors for coax to SAE and vice versa.
    Braintree, MA
    +1 on adapters -- there's no better way.
    -Tom (KA1TOX)
    Sep 2008
    Wilmington, NC
    I've powered my tank bag with inlet and an SAE Powerlet outlet port on which I use a 3" SAE to coax adapter that runs my jacket.
    You can get them in various lengths and Powerlet will also make you any type of custom length adapter you might want if its not already in their extensive list. Call if you have trouble deciphering the website- it needs some fixing- but their service is excellent.
    Nuckin' Futs! tonyfr's Avatar
    Apr 2007
    SAT - LAX
    Is there a line of heated clothing that uses this same connection?
    Tour Master has an adapter that goes from SAE to coaxial. I use this on my Tour Master heated jacket.
    SABMWRA MOA #62
    2005 BMW R1200RT
    1984 Kawasaki ZX750-E1 Turbo
    Oct 2012
    i went over to revzill and bought a gerbing liner and gloves. it came with a battery harness with a coax plug. i also got an SAE / coax adaptor, to plug the SAE battery-tender plug into the SAE end, and the coax end into the coax plug on the battery harness.
    my megaboost battery tender gave me a "reverse-polarity" inication, so i cut and reversed the two wires of the adaptor and now all is well. weird that i had to do that but it works now.
    BMWMOA #182796
    '76 R90/6
