Results 1 to 4 of 4
Thread: /5 32mm Bing Carb Stained from Simple Green?
    Apr 2012
    Los Angeles, CA
    Hey all,
    So I have a carburetor body that I am working on rebuilding (replacing all parts o rings/etc with new).
    So I disassembled the carburetor and soaked it in a 5:1 simple green solution.
    Due to the simple green not being deep enough, it now looks like I have a water line.
    Any idea how in the world to clean this off without using something abrasive? Is it corrosion? Kind of strange that it only happened right at the top "water line" of the simple green.
    Would this be considered "varnish"? If so would B-12 chem tool remove it?
    Note for next time, there is a Simple Green that is formulated for aluminum...
    http://www.amazon.com/dp/B001VXU7OE/...l_856u5fq7aj_e
    Otherwise, be fast and rinse thoroughly.
    Apr 2012
    Los Angeles, CA
    Quote Originally Posted by beemerphile View Post
    Thanks for the info. Definitely helps for next time, but I am more curious if the carbs is irreversibly corroded or not.
    No longer a member here
    Try to use NevrDull and see if the marks come off.
