Results 1 to 9 of 9
Thread: R75/5 with bent frame
    I have a 1973 R75/5 in my basement. It has not run in 23 years. It has a slightly bent rear frame. Is it possible fix a bent rear frame? I used to use it for delivering messages in Washington,DC, in the early 80s and it ran and handled just fine: bent frame and all.
    I bought a 2011 R1200R a couple of months ago. Now that I am riding again, I am wondering if it is worth restoring my old bike.
    The rear sub frame can be unbolted and replaced. The main loop frame holding the engine is a different story.
    As for the 23 year old bike: Get $3,000 to $5,000. Then decide if you want the old bike in good running shape or something else.
    Hey if you don't want it I'll take it! Ha! Restore it, I bet you'll be glad you did.
    I had to replace the sub frame on my '76 R75/6 and I found one on IBMWR for $25 + shipping. I have put about $3,000 into mine (not including original purchase) and that is "functionally" restored. I bought it off the sidewalk where it had been sitting under a tarp since 2008. That money included a new seat which was a pretty big number. It also includes the $200 for the electronic ignition and $300 for tires. The rest of the $$ went to small stuff like cables, various rubber parts, gaskets, seals, bearings and that sort of thing. The time spent is the biggest investment and I will spend this winter going over my mistakes and omissions. For me, the time and $$ are well spent and I have already made room in the garage for the next once this one is finished.
    Chip
    Registered User 88bmwjeff's Avatar
    Aug 2004
    Walnut Creek, CA
    Quote Originally Posted by tshammack View Post
    That all depends on how you are judging it. From a monetary point of view--Probably not, but could be. From a fun hobby sort of way, then I would say definitely. This bike clearly has some meaning to you otherwise you wouldn't have kept it for the past 23 years. Since you've got the R1200R to ride, take your time and have fun restoring the bike. At the end of the day (or project), you'll have your old bike back on the road.
    As far as the frame is concerned, you might be able to get it straighten. My attitude is anything man made can be repaired, rebuilt or replaced. However, with no photos, or description on how bad it is, I doubt you'll get a definitive answer here. If you take your time and start hunting, you should be able to locate a good used one, which will most likely be the best option as cseltz noted.
    Disclaimer: Keep in mind this is the opinion of one person who is a weekend mechanic with an average ability, but by no means an expert with regards to these bikes.
    Jeff in W.C.
    1988 R100 RT (the other woman)
    "I got my motorcycle jacket but I'm walking all the time." Joe Strummer
    Pismo Beach, CA
    It's not worth the time and effort to restore your /5. You should probably just drag it up out of the basement and dump in next to the curb. Someone will haul it off and get it out of your hair.
    Where did you say you live?
    Lew Morris
    1973 R75/5 - original owner
    Registered User dmftoy1's Avatar
    Mar 2012
    Lexington, IL
    Quote Originally Posted by lmo1131 View Post
    What he said. . . .heck I'll even haul it to the dump for ya for free if you've got the title. . .
    Sep 2003
    Virginia Beach
    Speaking of "bent", I finally ordered a new set of handlebars for my R60/6. They've been bent since '94, but the bike tracked straight and true through all its commuting days in Detroit and then Virginia. Now, maybe, I'll buy a strobe (or at least a test lamp) and set the timing for the first time since the factory. Did I hear the splines are supposed to be lubed now and again? Ha!
    Virginia Beach
    current:14 R1200RT 75 R60/6
    past: 11 R1200RT 10 R1200RT 03 R1200CLC
    Pismo Beach, CA
    I think I'd change the engine oil before I went to the trouble of lubing the splines... . .. [wink, wink, nod, nod]
    Lew Morris
