Results 1 to 15 of 16
Thread: '02 RT rear shock has two screws on each side, one is rebound, the other is???
    Cambridge Ontario (Canada)
    Hi, I'm looking at an OEM rear shock and see two screws one for rebound (H - S) and on the opposite side another screw with only notches. What does that notches screw adjust? (I'm not talking about the pre-load knob.)
    Thanks,
    Chris...
    neanderssance man sedanman's Avatar
    Jul 2011
    Pawling NY
    I would guess compression. It's all that's left after rebound and preload are accounted for.
    Paul
    Stop wrestling with your motorcycle, dance with it.
    2011 R1200RT Traded
    2014 R1200RT fully optioned
    I would have thought the same, but the owner's manual doesn't mention it. When I tried searching online only the rebound and preload were mentioned as possible adjustments? I put the screwdriver to the odd screw and it does turn to a noticeable detent on the various notches. (The shock has been removed from the bike.)
    Northern Front Range, CO
    Historically, BMW has only offered rebound damping and preload adjustment on their shocks (at best), never compression damping.
    how about posting a pic, to help us determine what you're dealing with?
    Ride Safe, Ride Lots
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by chrisz View Post
    Manufacturing process.
    The screw on the bottom, it doesn't do anything to the rebound screw if it is turned.
    Left Coast Rider
    Nov 2011
    With your picture of the shocks out of the bike are we correct in assuming you've replaced them with something else?
    The shocks in the photo are not mine. The photos are stolen off the web. But they correctly show the screw I inquired about on the rear shock. But yes I did replace my shocks with much newer OEM.
    I am going to take a wild guess: BMW doesn't make struts (shocks). Somebody makes them for them. Who exactly has changed over the years. I don't know who made yours.
    But, BMW specifies what it wants. Let's say adjustable preload and adjustable rebound damping. Now BMW isn't the only buyer of that supplier's shocks. So they take an off the shelf shock body and equip it with innards (highly tech term) to meet BMW specifications. If that off the shelf shock body happened to work with both rebound and compression damping but the valving for compression damping were left out of the insides, then an extra adjusting screw that didn't do anything would still be in that off the shelf body.
    I think they did, and they did, and they did, and that's what you get.
    Jul 2007
    THE BIG SKY
    I'll bet if you tried to order that extra screw it would be priced as if it were an essential BMW part.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Well of course, Kevin. It and the O ring around it is what keeps the oil from all falling out.
    Mar 2010
    Vancouver, B.C. Canada
    If the shock in the photo is the same as yours the big knob is your preload adjuster and the small screw adjusts the rebound damping on an 1100RT. Any others would just be assembly parts. Is that what you are after?
    Last edited by happy wanderer; 10-03-2013 at 03:36 AM. Reason: The usual confusion...
    Mar 2013
    Winnipeg, MB, Canada
    I have the same screw ON my 1997 RT
    This is a terrible photo, sorry, best I can do on my hands and knees with a beer in hand and camera in the other. [ATTACH]41949
    This is my "bouncy" adjustment. The "fat man" adjustment is the really big knobby doodad. The screw in the image from chrisz is staked tight on mine on the opposite side from my "bouncy" screw. There is no way it's moving. I would hazard a guess that this screw is the oil/gas fill and if it moves, things might be a bit FUBAR.
    3xR90/6, two just sold, one for a sidecar.
    1983 K100RS for winter project, two K's sold and just acquired a very rough R80RT.
    Fubar? I don't know, but it does turn on my and stops at the detents...
    Mar 2013
    If I can get a picture of my screw, I will. It can't be turned. The marks are from a stake tool and the edge of one slot has a center punch mark that keeps it from turning. I strongly suspect everyone here is right in assuming it's just a plug with an o-ring on it and it was the oil/gas fill. I would be reluctant to mess with it just in case it leaks. At that point, the shock is now two bouncy bits with a spring.
