Results 1 to 11 of 11
Thread: where does this ground strap attach?
    motorcycle cowboy Tennessean's Avatar
    Oct 2005
    East Tennessee
    Doing some wiring on my 2004 RT and found this ground strap unattached. Several years ago I had the headlight assembly replaced under warranty and I wonder if the tech overlooked it. You can see wear marks on the washer so I feel confident that it was attached at some point. The bike has no electrical issues. The picture is of the left dash right where the speaker is located.
    2013 Goldwing
    I don't know. But there are probably only one or two good ground locations it will reach. As long as you are positive it is a ground wire, pick one and hook it up.
    Oct 2005
    East Tennessee
    Well, I wouldn't gamble any money on it being a ground strap, but what else could it be? The other attached end is in the back ground.
    2013 Goldwing
    It is clearly a ground strap - woven, and uninsulated. Find a good chassis ground and hook it up, unless the other end is a good chassis ground. If it is, then you need to find the subassembly it is intended to ground. What is the other end hooked to?
    Oct 2005
    East Tennessee
    It's tough getting old. Now I remember. This bike is pre wired for a radio, has (had) the antenna attached to the left front. I took it off because the plastic mount was broken. Ground strap was attached to the antenna base.
    2013 Goldwing
    That makes perfect sense!!
    Aspiring Profligate Jeff488's Avatar
    Apr 2007
    Nacogdoches, TX
    Quote Originally Posted by 2bikemike View Post
    Jeez, do I know what that's like!
    '08 BMW R1200RT
    '75 Red R75/6
    '08 Suzuki DL650 "Screaming Yellow Zonker"
    Looking for Ed Sanders' Truck Stop.
    Jammess jammess's Avatar
    Aug 2005
    Florence, OR.
    Quote Originally Posted by jeff488 View Post
    Yup, I'm feeling it...
    Jammess
    Left Coast Rider
    Nov 2011
    What were we talking about?
    Aug 2006
    Southern California
    Pre wired for radio takes grounding from antenna to faring stay. I have the same thing on a 03 set up for a radio.
    Don't you just lov this board...
    Oct 2005
    East Tennessee
    Quote Originally Posted by lgb View Post
    I've learned a lot here. Most of which I've forgotten.
    2013 Goldwing
