Results 1 to 13 of 13
Thread: Rear end and trans oil change, what's the schedule? 2007 R1200R
    Barback King rapiddog's Avatar
    Jan 2004
    Acton, SoCal just West of Hell
    Question Rear end and trans oil change, what's the schedule? 2007 R1200R
    2007 R1200R
    15K
    I've had both an '05 GS and RT, plus several other oilheads and maintained them all myself.
    It occured to me this R though maintained by a dealer up to 11K, doesn't show any fluid swap on the rear end or tranny.
    This being the later gen hexhead (as oppose to the '05 bikes), what;s the word on gear oil and when and if to change it?
    I see that the rearend has a drainplug so I'm assumiong it's probably in need at 15K.
    Last edited by deilenberger; 09-25-2013 at 09:59 PM. Reason: added year/model to title
    "...the burble of my exhaust unwound like a long cord behind me. Soon my speed snapped it, and I heard only the cry of the wind...." Larry of Arubia
    Registered User wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    Cool
    new to BMWs....but i plan on changing the motor, gearbox and final drive lubricants on my 2013 R1200RT every 6000 miles....cheap insurance that...
    just completed the service at 6012 miles and 11 weeks of ownership...
    wyman
    ~wyman~
    2015 S1000R - Duke - Black Storm Metallic
    2013 R1200RT - Sassy - Fluid Grey Metallic
    Albuquerque, NM
    If you don't have the BMW service DVD--and you should if you intend to do ANY mechanical work on your bike--you can at least find the schedules at A&S BMW's website under resources.
    Kent Christensen
    21482
    Sep 2008
    Wilmington, NC
    Only if you do it yourself is it cheap anything...
    One accepted practice for the FD is every 12K or so though lube removed this frequently will be only modestly discolored. Remember that bearings are external on the newer drives. I do mine when I change the rear tire which works out to about 11K for mostly touring use of a PR3 on mine.The lube is cheap for 6 oz and it only takes 5 min if you're working on that end anyway.
    I do engine oil every 7-8K and that's more than one would do if you went by oil analysis and used best quality modern lubes. Even my diesel goes a lot further on factory recommendation and its a lot harder on oil than the boxer motor with its relatively large oil capacity (for a bike), separate tranny so little shear, and very little blowby and combustion junk getting into the oil
    Tranny is 24K but that's pretty conservative.
    Mansfield,MA
    This is the site referenced- http://www.ascycles.com/BMW-Motorcycle-Parts-Fiche.aspx it's listed in the Resources and Links subforum.
    The R&L is a good tour, provided buy Kurt.
    http://forums.forums.bmwmoa.orgdispl...and-References
    Mod Squad
    2009 F800GS 1994 TW200
    Apr 2012
    Los Angeles, CA
    Quote Originally Posted by wyman.winn View Post
    wyman
    That's quite excessive on the final drive & transmission. The factory spec for the transmission, at least, is every two years or 25k miles.
    http://www.ascycles.com/pdf/ServiceS...12K_Annual.pdf
    2000 R1100RT / 1987 K75C (RIP) / Santa Clarita, CA
    Jul 2013
    Solvang, CA
    Quote Originally Posted by JamesInCA View Post
    iin your opinion....oil is cheap and my time is free.....
    never had an engine/tranny problem with changing the lubricants too often.....
    wyman
    ~wyman~
    Your manual will tell you BMW's recommendations. It PROBABLY says - engine oil every 6,000 miles unless severe service (lots of short trips, winter riding, or very dusty conditions) in which case they would cut that in half.
    Transmission and final drive: 24,000 miles or every two years.
    What I do: Engine oil at 6K. Transmission 24K or two years. Final drive - with engine oil at 6K.
    I know the lube is fine in the FD, but I want to inspect the magnet for the earliest sign of a problem. This applies specifically to R11xx and K75/100/1100/1200 drives with the bearings in the oil. The big hole drives I would change per BMW specs - probably 24K 2 years, but look it up.
    P Monk
    May 2005
    Port Neches, Texas
    Who Uses Castrol SAO
    or BMW Transmission and FD synthetic. I prefer the BMW because it is very clear when I change it out with each new rear tire and I can look for metal in the oil.
    Had the dealer change FD oil last time and they used the Castrol. Wasn't that supposed to be the lifetime oil when the new FD's came out?
    P. Monk
    74 R90/6 (also know by bride as the Black Hole). 09 R1200 GS. My wife, 1953 model who has survived aplastic anemia and a bone marrow transplant.
    Missin' my Dog vegasgsa's Avatar
    Jun 2013
    The NorthWet
    Oil every 10K..Amsoil 15W-40 Marine and Diesel
    Tranny and Final every 20K...Amsoil 75W-90 Severe Gear Final, 75W-140 Severe Gear Tranny
    Spring Lake NJ, USA
    RapidDog - please review http://forums.bmwmoa.org/showthread.php?46055.
    The service spec's changed a few years ago, so this info is good to have in the thread title.. I'm adding year/model to your thread title.
    neanderssance man sedanman's Avatar
    Jul 2011
    Pawling NY
    FYI, Land Rover uses Castrol SA-XFO in one of their suv's . I bought my supply from a Land Rover dealer for less than $7 a quart. They have a chart at the parts counter that will identify which part number is SA-XFO (it doesn't say it on the bottle).
    Paul
    Stop wrestling with your motorcycle, dance with it.
    2011 R1200RT Traded
    2014 R1200RT fully optioned
    I have found that my FD and gear case oil starts to get dark at around 10000 km's or 6000 miles and thats when I change them. Doesn't necessarily mean they are bad, but not expensive to do myself so why not ?
