Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Thread: 1998 R1100RT Evaporative Emissions System
  1. #16
    Mar 2013
    Winnipeg, MB, Canada
    If I repeated what Pauls1150 said,
    Could you make it a little clearer, what your post refers to, so that simple minds like me, know what you are talking about??
    Sorry if I was too vague. In Canada, calling our First Nations People "Indians" is considered rude and it hurts the feelings of the people from India. It's considered bad taste to refer to people that live in Quebec as "those french lunatic bastards".
    By far, we are way too tolerant as a nation and if you get carried away with political incorrect comments, we joke that you have to go south of the border to express how you really feel. Hence, many friends just get fed up and move to the US.
    If this was a Canadian web site, Pauls1150 and my comments would have to be deleted.
    I choose to live in a socialist country, but I also have to "sensitive" to others.
    Yeah, it's crap. Its great to see people express themselves.
    3xR90/6, two just sold, one for a sidecar.
    1983 K100RS for winter project, two K's sold and just acquired a very rough R80RT.
  2. #17
    No longer a member here
    Apr 2006
    Mmmh....maybe it was deleted, but I can't find any reference to any "Indians", neither West- nor Amercian- nor Asian-....
    Only thing I see is Paul's interpretation of the acronym CARB, with which he may actually not that far off....
  3. #18
    Jun 2012
    Phoenix
    16 replies but....
    Well,
    16 replies/opinions as to the various attributes/merits of the system, but pretty much exactly as I expected when I noted that this is not about that.
    Not a single contributor has the answers I'm needing to get my machine back in service like I want it.
    Since the last post, I have obtained the canister & related brackets. I now have the solenoid valve and some of the hosing.
    I note that the 3 hose nipples on the canister have no markings at all to indicate which hose goes to what (helpful).
    I found a hand written diagram in another post indicating that 1 of the 2 hoses from the tank goes to the canister. (I assume that is the one that does not go to the fuel cap water/overspill drain).
    That leaves the only other one from the tank going to the canister.
    Then 1 of the 2 other hoses from the canister routes to the purge solenoid valve.
    The hand written drawing shows the 3rd hose from the canister going aft as an overboard drain (Doesn't sound right)
    I have the route from the solenoid purge valve towards the throttle bodies figured out at the back 1/2 but nothing yet on the T/B connections, the Tee fitting or the proper routing of those hoses.
    Thank you for the one poster that said he had one apart in the shop and intended to post some photos.
    Those haven't shown up yet.
    Can someone who actually understands the system please post up some more help?
    And to all you fella's who ripped your systems out........I'd be happy to get a few more of the OEM parts that I'm missing.
    Thanks in advance, Ibjman
  4. #19
    The RT I have at the shop is ready for me to take pix of. I also have an 1150RT there with the same setup. Will try to get pix tomorrow.
    Solenoid on left, zigzag hose runs forward under the frame rail (on the outside) to the T fitting. from the T there is a short hose to the left TB and a longer one under the battery tray to the right TB.
    The canister should have letters stamped by the tubes.
  5. #20
    This is from memory but I think:
    The canister has three spigots: 1 large and two small.
    The tank has a large spigot.
    Each throttle body has a small spigot.
    The valve on the left side by the seat has an in and an out.
    Connect the tank vent to the valve in.
    Connect the valve out to the canister big spigot.
    Connect each of the small canister spigots to the throttle bodies.
    Make sure the electrical connection to the valve is hooked up and clean.
    If the spigot count fails to match, then I am wrong. It sometimes happens.
    If the canister has only one small spigot then it goes to a T and then the throttle bodies.
    We are just moving air here.
  6. #21
    Jun 2012
    Phoenix
    OK - Thank You
    I plumbed it all up today based on what knowledge I had found so far.
    Based on Anton's thread, I may have it wrong. Perhaps I should have inspected the charcoal canister more carefully, I saw no markings.
    Currently I have at least 1 original pre-formed hose....it has about a 2" diameter square "U" shaped on one end. I installed that on the front of the Purge valve making the "U" take it up and then toward the back. From there, I rerouted the other end of the hose across the frame and forward to the area in front of the air cleaner. At the front of the air cleaner (right) I inserted a TEE.....from the tee the hose is split down to each TB
    The back side of the purge valve connects up to another formed hose.
    From the back of the purge valve the hose goes into a purpose built hole in the frame, makes a 90 deg. turn, goes across the back of the relay box and makes another 90 deg. turn (down) and ends just above & forward of the charcoal canister. I added a union there and connected that hose to the center port on the canister.
    The hose coming back from the (in)tank vapor line is connected to the top port on the charcoal canister.
    The 3rd (bottom port of the canister is routed to road dump at the rear master cylinder linkage.
    The other tank hose from the fill cap area is also routed to the same overboard dump function.
    Currently, If I have guessed correct, Flow goes from the tank to the top port of the canister. From the center port of canister - across to the frame to the back side (inlet?) of the purge valve. Through the purge valve (when activated) out the front side of the purge valve, around the "U" curve, back across the frame and forward to the throttle body vacuum source.
    I'll be waiting anxiously for as many detail photos as I can get to learn if I have to pull the fairing sides back off & make changes.
    As I read the posts, On respondent says the purge valve should go between the fuel tank vapor line and the inlet of the canister.
    Currently I have it between the outlet of the canister and the purge vacuum source (throttle bodies)
    The directional arrow on the purge valve clearly shows it should flow from the back to the front.
    I haven't had any opportunity yet to view a Clymer published manual to see if it might include this system???? Anyone know?
    Thanks, Ibjman
    I am not at all sure about having the bottom port of the charcoal canister dumping overboard.
  7. #22
    passinthru
    Just east of Reno
    Carbon canister hose routing
    http://www.advrider.com/forums/showthread.php?t=738699
    This may answer the questions you have about the routing of the hoses to and from the
    carbon canister
  8. #23
    Jun 2012
    Phoenix
    Thank You
    Well, The only piece of useful info. seems to indicate that the fuel vapor line from the tank should connect to the center port of the canister????
    I'll have to tear the fairing side off again tomorrow & re-inspect. I believe I have the fuel tank routed to the top port.
    Also, I just viewed a U-tube video where a guy showed how to tear the system out (great technician, what a butcher!).......His video appears to show the purge valve installed 180 deg. from what I have. It does show the OEM purge hose set up......wish I had one of those original Zee hoses (not serviced at BMW).
    His set up looked OEM........I'll have to have another look at that arrow on the valve too.
    Still need more photos....especially showing the correct connections to the canister.
    Thanks, Ibjman
  9. #24
    No, that isn't right at all for an R1100RT.
    Tank (without XXX) to canister FT spigot
    E spigot to solenoid to T-fitting to throttle bodies
    Last spigot (forget the letter) to ground; it's a drain.
    I'll get pix one of these days.
  10. #25
    Oct 2011
    Florida & Massachusetts
    They key thing is to make sure you have the correct line coming from the fuel tank. You want to figure out which one is the filler neck drain and which is the overflow/vent line. Use the Overflow/vent line to the cannister. Here's how it is plumbed:
  11. #26
    For reinstallation purposes, that diagram could be FAR better.
    Their hose G meets the canister at canister mark FT.
    Their hose E meets the canister at canister mark A
    Their hose D meets the canister at canister mark E
    Their hose H connects to the hose marked X-X-X
  12. #27
    Jun 2012
    Phoenix
    OK thanks
    I have that hand drawn diagram. I believe that I may have it connected correctly.
    There is still a question about which way the purge valve is to be installed and the significance of the "Arrow" imprinted on the valve. I assumed it was for direction of flow through the valve, but one online video seems to show the valve installed with the arrow pointing aft. Who knows?
    I'm still hopeful for some detail photos so that I can verify the installation direction of the valve + tidy up the routing arrangement of the various hoses.
    currently I appear to have the vacuum hose from the purge valve to the throttle bodies connected correctly but routed incorrectly.
    I hope to have it look as close to original as possible with all the proper clips and clamps in the correct locations.
    Best case scenario: I will someday be able to find some of the original pre-formed hoses that SOOOOO many other uses have since removed.
    Someone has these laying on a shelf collecting dust in their shop!
    Thanks, Ibjman
  13. #28
    See what about 18 years does to a guy's memory?
