1998 R1100RT Evaporative Emissions System
ibjman
I have just obtained the 1998 R1100RT from California that the PO apparently removed & discarded the entire Evap system.
I'm a STRONG believer in staying completely stock and I need some help/resources to restore this system to original.
I have yet to find any vacuum hose routing diagram.
Currently I have:
2 long rubber hoses coming from the right side fuel tank area and running back to dump on the ground near the R/R swing arm below the rear suspension adjuster knob.
1 short rubber "U" shaped hose across the back of the relay/fuse box connected to nothing. I assume the right hand end should be the outlet of the charcoal canister & the left side end should connect to the purge solenoid inlet.
1 rubber holder (mounted to the left rear frame rail) for the purge solenoid.
1 electrical plug for the purge solenoid.
I have the parts diagram of the associated parts.
I have yet to find any idea where the purge solenoid outlet hose & Tee connector reconnect to the air inlet manifolds.
Anyone with a way to provide some resources picture, drawings, parts etc. will be a big help!
This is not a discussion about the merits of having/removing the evaporative system. I am going to reinstall it.
Thanks in advance, Ibjman
Currently I have:
My PO also removed the carbon canister and did the remote filter mod.
The stated reason for removing these is that sometimes the carbon "dust" ? gets loose, and sucked back into the fuel tank somehow.
From there plugging up the fuel filter.
I'm assuming this actually happened, that filter is not something you'd go in after for fun. Although doing both seems silly.
I did not like the remote filter mod because the filter is unpainted, and the only available space for it is right next to the back tire.
It will rust and eventually leak. So I noticed some rust (no other problem with it) I installed a new one into the tank where it belongs.
I don't lean strongly in either the modify or remain stock directions but I would like to know if the carbon clogging issue is real and if anything has been done to fix it. I would think you could splice one of those little inline fuel filters into the vapor lines to prevent carbon from escaping.
Surprised not to find any mention of the charcoal canister or vent lines in the factory manual. My '00 RT's charcoal vent system did not survive it's maiden voyage home. After fluid changes and new tires that was the first thing to go.
Given the problematic charcoal canister that probably won't survive a bike tip over, lots of hose and connections for vacuum leaks to develop in an already sensitve vacuum balance environment just did not appeal to me. Pulled all that stuff out and replaced it with two simple rubber caps on the throttle body vacuum ports. Now the only place for vacuum leaks is obvious.
I've seen some guys run a vacuum hose between the right and left side throttle bodies as well.
Only bikes that were delivered to The US had the charcoal canisters. European and the rest of the world bikes were charcoal free completely stock.
There have been cases of the charcoal granules being sucked down through the vacuum lines and into the injectors, then into the engine. THAT is Reason Number One to nuke the whole shebang and install two little caps on the injectors' bottom ports.
Reason #2 is that the extra hoses & fittings provide many more places for little vacuum leaks to happen, either from dried-out lines or cracked plastic. Not only does this allow unfiltered air directly into the injectors, it also affects the throttle bodies' balance.
Reason #3 is that if the canister gets clogged from too much gas, you can get a vacuum inside the tank - causing the plastic to collapse.
Considering that European smog rules are just as stringent (if not more so) than California's, there really is NO reason - other than political - to have the [darn] thing on there.
Only bikes that were delivered to North America had the charcoal canisters. European and the rest of the world bikes were charcoal free completely stock.
I thought only California bikes had these. I don't think my 99RT has one???
CARB says you can not vent into the atmosphere. That's why they have it.
North America includes Canada and Mexico. Don't know about Mexico but in 95 and 96 the RT bikes shipped to Canada had no charcoal canister. They also had no O2 sensors or Cat Code Plugs. So not _all_ oilheads delivered to NA were the same. In 97 BMW stopped shipping Euro models to Canada and started shipping USA models instead. I suspect they did the same for Mexico but do not know for sure.
I am sure about the Canadian RTs though because I had one and looked into why it was different. It's all in the fiche.
Pauls1150: Agree with everything you stated except for charcoal granules getting sucked into fuel injectors and into the engine. I don't see how that is possible. The vacuum lines from the canister connect into the bottom of the throttle bodies. Injectors don't suck, they spray from the top. I can see junk getting sucked into the engine but not the injectors.
I didn't state it correctly:
The granules get sucked down the hose to the bottom of the throttle bodies, thence up into the fuel flow and into the intake.
The idea of an in-line filter is interesting, but you'd need to adapt to the change of hose size in at least 4 places.
Ah yes, those California Arrogant Retarded Bastards... the same appointed folk who decided to put a highly carcinogenic additive into our gas; then when it was discovered that it was leaking thru the underground tanks into the water & soil, they demanded that everybody install new tanks - so costly that they forced many gas dealers right out of business, including several in the "desert crossing" zones.
Now that figures. I wonder what charcoal granules would do after they got sucked into a cylinder. Not anything good I'd imagine.
California is such a huge market share for auto, truck and bike makers that no matter what regulations are imposed they pretty much have to go along with it or lose that huge market share. So California is really in the driver's seat on safety and environmental legislation and it's consequences whether it makes sense or not.
It always amazes that the entire population of Canada and California remained very close to equal for quite a few years. But last year Canada was 34.8 million and California is now 38 million.
Now Canada is one vast country for sure but although California is a very large state, it's still just one state! That is a lot of people...and cars, and trucks and bikes. Impact of scale rules the day I guess.
Typically they weld themselves to a valve seat - a double whammy, since now the valve can't close and the grit is so hot. I've seen photos of the damage (never saw it first-hand, thank goodness), and it sure ain't pretty.
Yeah, we've got way too many people, especially in the southwest... We really need the San Andreas Fault to let go, and wash it all away with a follow-up tsunami.
http://www.data.scec.org/recenteqs/
Duh, can you express a non technical feeling here?
If I said any of that stuff about our First Nations Aboriginal People or our Distinct Culture Second Language Citizens, I think I would be given an American Passport and shipped away....................Wait, maybe that's why he went back to the US. He is a US citizen and says stuff like that all the time.
Could you make it a little clearer, what your post refers to, so that simple minds like me, know what you are talking about??
If I repeated what Pauls1150 said,
Sorry if I was too vague. In Canada, calling our First Nations People "Indians" is considered rude and it hurts the feelings of the people from India. It's considered bad taste to refer to people that live in Quebec as "those french lunatic bastards".
By far, we are way too tolerant as a nation and if you get carried away with political incorrect comments, we joke that you have to go south of the border to express how you really feel. Hence, many friends just get fed up and move to the US.
If this was a Canadian web site, Pauls1150 and my comments would have to be deleted.
I choose to live in a socialist country, but I also have to "sensitive" to others.
Yeah, it's crap. Its great to see people express themselves.
Mmmh....maybe it was deleted, but I can't find any reference to any "Indians", neither West- nor Amercian- nor Asian-....:scratch
Only thing I see is Paul's interpretation of the acronym CARB, with which he may actually not that far off....:thumb
16 replies but....
Well,
16 replies/opinions as to the various attributes/merits of the system, but pretty much exactly as I expected when I noted that this is not about that.
Not a single contributor has the answers I'm needing to get my machine back in service like I want it.
Since the last post, I have obtained the canister & related brackets. I now have the solenoid valve and some of the hosing.
I note that the 3 hose nipples on the canister have no markings at all to indicate which hose goes to what (helpful).
I found a hand written diagram in another post indicating that 1 of the 2 hoses from the tank goes to the canister. (I assume that is the one that does not go to the fuel cap water/overspill drain).
That leaves the only other one from the tank going to the canister.
Then 1 of the 2 other hoses from the canister routes to the purge solenoid valve.
The hand written drawing shows the 3rd hose from the canister going aft as an overboard drain (Doesn't sound right)
I have the route from the solenoid purge valve towards the throttle bodies figured out at the back 1/2 but nothing yet on the T/B connections, the Tee fitting or the proper routing of those hoses.
Thank you for the one poster that said he had one apart in the shop and intended to post some photos.
Those haven't shown up yet.
Can someone who actually understands the system please post up some more help?
And to all you fella's who ripped your systems out........I'd be happy to get a few more of the OEM parts that I'm missing.
The RT I have at the shop is ready for me to take pix of. I also have an 1150RT there with the same setup. Will try to get pix tomorrow.
Solenoid on left, zigzag hose runs forward under the frame rail (on the outside) to the T fitting. from the T there is a short hose to the left TB and a longer one under the battery tray to the right TB.
The canister should have letters stamped by the tubes.
This is from memory but I think:
The canister has three spigots: 1 large and two small.
The tank has a large spigot.
Each throttle body has a small spigot.
The valve on the left side by the seat has an in and an out.
Connect the tank vent to the valve in.
Connect the valve out to the canister big spigot.
Connect each of the small canister spigots to the throttle bodies.
Make sure the electrical connection to the valve is hooked up and clean.
If the spigot count fails to match, then I am wrong. It sometimes happens.
If the canister has only one small spigot then it goes to a T and then the throttle bodies.
We are just moving air here.
