Results 1 to 15 of 15
Thread: Turning the Scooter in tight spaces?
Hybrid View
    Sep 2013
    Hi All
    My driveway is sloped just about all the way up to the garage.
    My garage is limited in width. (it's one of those 1,5 car garages with work table and cupboards either side)
    Turning the scooter around in the garage is a small challenge every time.
    If I try to turn it on the driveway, its difficult, due to the slope.
    I have basically to do several iterations of backwards and forwards in the garage to get it around. (5 point turn, so to speak)
    Having to lift the side stand, also makes this maneovour tricky.
    On previous BMW R Series, I could swing the bike on one leg of the center stand.
    I know this is a well known tactic but not sure if it is Motorrad sanctioned?
    Because of the very rear position of the Scooter center stand, this is just about impossible?
    There is a lot of weight on the front wheel.
    Anyone have any suggestions?
    I am thinking of a very low, 3 wheeled triangular cart, which I can slip under the front wheel, to act as Dolly.
    Then should be able to swing the bike around on the c/stand and front wheel dolly.
    Hopefully though, someone has this problem already figured out?
    I did a quick thread check but could not find the answer.
    Thanks,
    Mike.
    On The Road Again
    California
    Lightbulb
    On a polished floor I use a 1/4", 12 x 18' plate, with teflon buttons on the bottom.
    Put scoot center stand on plate, Bob's your uncle.
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    -Albert Eienstein
    Sep 2013
    Thanks Ken and Omega Man,
    The park N move may well be the easiest solution.
    Have either of you perhaps tried it on the Scooter?
    If not, know anyone who has?
    Positioning the pNm and then lifting the bike onto it.
    The actual platform of the pNm looks quite low, so guessing the extra lift is not unmanageable.
    Mike.
    Mansfield,MA
    Hi Mike, welcome to the forum! Take a peek at this site- http://www.legalspeeding.com/Park-n-Move.htm
    There have been threads on this "Park and Move" before and it seems well received.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Nov 2005
    Calgary, Alberta
    Mike:
    I ride mine in and park it parallel to, and ahead of my car. To exit, I get on the bike, walk it out backwards, and do a 90 degree reverse turn onto the garage apron, parallel to the front of the garage, then put it back on the stand. Works good.
    I find that as long as I'm straddling the bike, I can control it.
    Rinty
    rabid reader dbrick's Avatar
    Santa Cruz CA
    How long is the driveway? Is it straight? If not too steep, you could just paddlewalk backwards out of the garage and roll down to the street.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Sep 2013
    Thanks dbrick,
    I have to negotiate between 2 * parked cars.
    Its tight going forward but relatively easy to do. Just got to be careful.
    Trying to go backwards freewheeling down the hill, I have yet to try!
    Regards,
    Mike.
    Sep 2013
    Quote Originally Posted by RINTY View Post
    Mike:
    Hi RINTY,
    Thanks for the suggestion.
    I have a very narrow garage apron before the slope.
    I have already tried that technique and it is do-able but a hassle.
    The easily swiveling of the R-series bikes has spoilt me!
    Mike
    RK Ryder
    London, Ontario
    The car occupying the left side of our driveway is always parked close to the sidewalk, leaving a decent amount of space in front. When returning home, I ride up the driveway, making a left turn in front of the car on the left. From there I paddle/walk it backwards 90 degrees into the garage, ready to be ridden out for the next trip. The other bike is (whichever one it happens to be) is parked on the lift, and when it exits, I make a 90 degree turn out of the garage in front of the left parked car. From there, I fire it up and ride out. Granted, I do have a sloped, three lane driveway, but not a very steep incline.
    If you wish to pay for shipping, feel free to have my turn table affair that I bought years ago from the Duluth Company. I never had much success with it, but it might work for you if the centre stand is at the back of the scooter. I did not have enough weight to lift the front up and pivot the bike around.
    Paul
    Knights of the Roundel #333
    Sep 2013
    Quote Originally Posted by 30300 View Post
    Thanks 30300,
    I will goggle Teflon buttons and see where are they available.
    Approx how many buttons did you use on the 12" * 18" plate. On a 2" centre-to-center spacing?
    You using the plate on a typical cement garage floor? You mentioned polished floor?
    Do you think it would work on an unpolished cement garage floor (smooth finish)
    I do not know if I have lost all my strength, but for the life of me I cannot lift the front wheel when the bike is on its center stand.
    Even standing in front of the wheel and grabbing the wheel rim with both hands.
    So, assuming that once you have the Scooter on the plate, do you just swing the back of the scooter around, with the front wheel acting as the center pivot point?
    Thanks a lot.
    Mike
