Results 1 to 15 of 25
Thread: Marvel Mystery Oil in my 2002 RT
Hybrid View
    When I first purchased my current RT it had 36,200 miles on the clock. I pulled the valve covers and cylinder heads for inspection. The valve ports were pretty dirty and had built up carbon on them. The piston tops looked about the same with a 3mm carbon ring. A carbon ring around the perimeter of the piston is actually a good thing (if you weren't aware of that).
    After flushing all the fluids I ran 2oz of Marvel Mystery Oil per tank and have been doing that over the past 2,700 miles. I did a high-speed trip from Colorado up to Hardin, Montana last week and averaged 78 mph. This helped heat the piston tops over a long period of time to assist in cleaning them.
    I pulled the valve covers and heads last night. All of the carbon buildup inside the ports, on the valve faces and on the pistons is now gone but the carbon ring is still there. Couldn't ask for anything more from this great product. To get the interior this clean you would normally have to do a mechanical cleaning such and a chemical soak and glass beading.
    Try it and your Beemer will run better and more efficiently than it ever has.
    Sent from my iPhone
    No longer a member here
    Where can I buy it? Do you accept orders???
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Marvel is available at most auto parts stores; they are not associated with Amsoil (as far as I know...).
    It is an extremely high-detergent oil, and does break down carbon buildup.
    I've even been party to pouring it (slowly) directly down a car's carb to clean up the intake valves (and the tops of the pistons). The car smoked like a Florida mosquito fogging truck, but it worked.
    Vancouver, B.C. Canada
    One of the mechanics down at Ozzie's BMW in Chico CA suggested I try Marvel Mystery Oil in my '96 RT which had serious surging issues that defied any attempts to rectify the problem until I got to the bottom of it much later on. The thinking was it might help clean and lube the injectors. I ran several tanks dosed with the mystery oil but the surging mystery persisted. I can't say it helped or hurt really as I noticed no change.
    I do know it's been around for a very long time and many old time mechanics swear it works wonders on dirty, old and worn engines. They are mostly talking carbureted V8s and such though.
    So you took your heads off at 36,200 and the again 2700 miles later to see what the mystery oil was up to? That's dedication! Do you have any before and after photos? Pictures tell a great story for claims such as these.
    Please post them if you have some.
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Wow! You must be made of money...
    4 x cylinder head gasket (11 12 1 342 394 CYL. HEAD GASKET, 3 COMPONENTS (to 12/02) $49.97) in 2700 miles that's $200 before any taxes just to monitor carbon?
    Or did you re-use the old head gaskets?
    When you pulled the heads at 36,200 miles, why did you not decarbon while they were off?
    You ask us to believe you actually reassembled without cleaning and then used the Marvel Mystery Oil just to prove it works??????
    Why did you not use a borescope? They are cheap in comparison and much less labor.
    Do you have any before and after pictures?
    Please post as we are all very interested to see.
    Ufda happens..........
    The OP did not state how the inspection was done, but I would highly suspect that he did use a borescope.
    Ken
    He said he pulled the heads. (Twice) See post #1
