Bump
Come on folks, surely there are some of you running aftermarket tire pressure monitors!!
Running the OEM unit. Don't like it.
Too many 'false positives' that are both irritating and visually distracting. Have run into many riders (both OEM and aftermarket) who raise similar complaints.
While the automotive industry seems to have dialed this in correctly, current motorcycle technology (with tires that heat up more dynamically) lacks credibility.
Check your pressures with a quality hand-held gauge whenever you deem appropriate.
I completely agree. Is it really that much trouble to get a good air pressure gage and check it the old fashioned way?
The value of a TPMS is the alarm function that goes off in real time once pressure drops a few PSI giving the rider the opportunity to find a safe place to get off the road before handling is impaired at all. .
