Results 1 to 5 of 5
Thread: 1995 K75 rear brake
    1995 K75 rear brake
    I have a naked 1995 k75 approx. 30,000 miles. I had an all inclusive check done around 28,000 at a reputable shop. They checked to rear brakes and I was told that the bike had to have been dropped and that caused air to come into the brake line. They bled the brakes and they operated normally. The bike has not been dropped then and now but the trouble persist. I see no leak on the floor of the shed and it has plenty of fluid. Anyone have an idea of what my next course of action should be. Rebleed the rear brake again?
    Belton Tx
    I have dropped my 91 75RT on both sides and neither time did the brakes fail. It is likely that the rear master cylinder is leaking internally.
    Ron
    91 K75RT ABS
    Do you have ABS?
    If not, Ron's suggestion is a likely possibility.
    Feb 2009
    Mississauga, Ontario
    Is rear brake not working at all? Not clear as to what the actual problem is.
    Walter
    H. L. Mencken
    1995 k75 rear brake
    Quote Originally Posted by roncooper View Post
    I failed to mentioned that my bike is equipped with ABS
