Results 1 to 5 of 5
Thread: Starter problems
    SAY 1 Let's ride ayaple's Avatar
    Apr 2006
    Finger Lakes Region N.Y.
    Starter problems
    Starter bendix does not engage after short rides. Starter motor spins but does not engage in fly wheel second or third try engine starts fine. 2004 R1150 rt, 65 k dealer full service at 60K.
    Any Ideas worried it might take more than 3 tries
    Art: bikes
    '04 R1150 RT Mine
    '00 R1100 RT Hers
    #13338 PGlaves's Avatar
    Oct 2003
    "Big Bend" TX
    Here is the deal. Power is reaching the solenoid. The solenoid is engaging. This closes contacts and energizes the motor. But, when the solenoid engages and pushes the nose gear and drive forward the gear teeth are not reaching the flywheel.
    The starter needs to be removed. Two bolts and two wires after the left size plastic is removed. It is possible that the fork that moves the nose gear is bent, but it is far more likely that the shaft and nose gear just need to be thoroughly cleaned and lubricated. I would use electric motor cleaner and compressed air to clean things up and oil to lubricate the gear and shaft.
    Dec 2011
    Disount Starter
    My solution a year ago was www.discountstarterandalternator.com. A new starter, delivered for $71.90. It fit perfectly and still works great on my R1100RT.
    Dan Benson
    Lucky MotorradMike's Avatar
    Jun 2008
    Ontario
    What Paul said.
    I can do this on an RS in under half an hour.
    I've read the tupperware removal on an RT is long but the starter part is easy.
    That's a great site Dan!
    Thanks, and welcome.
    Mike Marr
    Apr 2006
    Quote Originally Posted by ayaple View Post
    Thanks Paul , Dan , and Mike. If it rains this weekend I'll start to peal the plastic off to clean and lubricate to alleviate my worries,
    Art
    Art: bikes
    '04 R1150 RT Mine
    '00 R1100 RT Hers
