Results 1 to 10 of 10
Thread: 91 K75s wider bars
    Registered User plehman's Avatar
    Nov 2006
    Arlington, MA
    91 K75s wider bars
    Anyone ever experiment with wider bars on a K75? I spent a 1000 miles on a new GS (not my own), came home and found my old K75 felt really funny. That's odd since I have so many more miles on it than a GS.
    I have a feeling it will be a real pain to widen (bars, cables, etc.), but it could give more control and leverage.
    Any thoughts?
    #13338 PGlaves's Avatar
    It can be done. Lots of folks have transplanted BMW K75C bars without issues. But other transplants require new wiring for the controls, new custom or mismatched cables, and new brake lines. Wider bars may also have clearance issues with the fairing or windshield.
    Astatula, FL
    C-bars
    The K75 C bars have been the upgrade standard for K100RS. Flatter, wider and about 1 1/2 " higher and further back. I didn't have to change anything on my '89 K100RS to make them fit other than the angle of the banjo fitting on the master cylinder, just loosened enough to turn it.
    Tip: slide the control assemblies onto the bar before you bolt it on.
    Bob Weis
    '04 K12RS - Hannigan Hack
    www.earplugco.com
    Nov 2006
    Arlington, MA
    Excellent - thanks guys. I'll see if Duncan's Beemers has a set and report back anon.
    Also consider the K100 Standard bars - I believe similar rise and setback of the K75C bar, but a little bit wider. I put them (along with the heated grip kit which included the bar, NLA unfortunately) on both my K75S and my K1100RS and it made a world of difference.
    Ted
    1994 K75RT
    Moto Pages
    Jun 2012
    Olympia, WA
    I started with RT bars then moved to C bars and eventually S bars.
    The RT setup uses the longer clutch, throttle and TPS cables while the C and S bars share the shorter clutch, throttle and TPS cables.
    I've never had to change any electrical cables when switching bars.
    I bet the longer RT versions of the cables would work best with wider bars.
    Slipster Slipster's Avatar
    Jun 2012
    Broken Arrow, OK
    fwiw: I prefer the S Bars
    Expect The Unexpected
    Aug 2012
    If you can find them, how about bars from a K1? It is my understanding that they are still low like the "S" bars, but wider. It seems to me that would be the best of both worlds.
    Lynn
    MOA #57883
    Jun 2007
    Minneapolis, MN
    +1 Mine is an "S" model - I'm going to an "S" bar, possibly with my handlebar risers as I've got a Parabellum and the C's hit the windshield when trying to make a tight turn - not safe!
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    Ken,
    I would suggest that you PM plehman and see about working out a trade. REMEMBER, no negotiating on the forum. PM only.
    Just be sure to go through the differences in the dash pad and the master cylinder brake hose.
