Results 1 to 10 of 10
Thread: Tire Pressures
    Registered User ItsPhilD's Avatar
    Sep 2013
    Phoenix, AZ
    Tire Pressures
    What tire pressures is everyone running? Please include:
    Scooter Model:
    Front Tire PSI:
    Rear Tire PSI:
    Current Miles:
    Tire Mfg:
    Tire Model:
    Temp Zone:
    Sep 2013
    Phoenix, AZ
    Scooter Model: 2013 C650GT
    Front Tire PSI: 35
    Rear Tire PSI: 44
    Current Miles: 4200
    Tire Mfg: Metzler
    Tire Model: Feel Free
    Temp Zone: 85 to 110
    32/35 here.
    Scooter Model: C650 GT
    Front Tire PSI: 35 (as recommended)
    Rear Tire PSI: 36 (as recommended)
    Current Miles: 8,000 miles
    Tire Mfg: Metzler
    Tire Model: FeelFree
    Temp Zone: 50F-105F
    Sep 2013
    Phoenix, AZ
    Where did you see 36 PSI as recommended?
    Jeff Wilson life member 43362's Avatar
    Jun 2012
    Richmond Hill Ontario Canada
    Quote Originally Posted by ItsPhilD View Post
    The sticker under the seat. There is a similar one in the right hand glove box.
    The one thing I do not necessarily agree with is if I am going to away for a weekend with luggage I will put the tire pressure somewhere in the middle of solo riding and two up as my gear for the weekend will be less weight than my girlfriend. The tire pressure is important because if it is to high you will have less rubber on the road and if the pressure is to low your tires will wear poorly and run to hot
    Jeff
    A bad day on the C650 GT scooter is better than the best day at work
    Mar 2011
    socal
    2013c650gt
    1200 miles
    Recommended front 35
    Rear 42
    35f/40r
    Jun 2012
    Olympia, WA
    Quote Originally Posted by 43362 View Post
    ... my gear for the weekend will be less weight than my girlfriend. ...
    Find a skinnier girlfriend and you'll cut down on tire inflation / deflation time.
    Quote Originally Posted by timtyler View Post
    Dude, does your gf see your posts here? That kind of post'll get a man cut off!
