Results 1 to 5 of 5
Thread: Spark plug thread repair
    Registered User LCampbell's Avatar
    Nov 2006
    Vacaville Ca.
    I'm looking for someone who can repair the spark plug threads (14mm x 1.25) in a cylinder head. The stock threads were stripped & then repaired using a Time-sert type fitting that is now loose in the head. I will try removing the insert so I need someone who can weld up the plug hole & then drill & tap it for a stock sparkplug.
    Larry Campbell
    2011 R1200RT, 92 R100RT, 75 R90S, 70 R75 Race, Vintage Kneeler sidecar R75 powered
    Pismo Beach, CA
    Ted Porter's Beemer Shop in Scotts Valley would be my choice.
    Might as well pull both head and have them both done while you're at it.
    Better hurry "rebuilding season" is nigh.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Nutfarm
    Apr 2008
    Folsom CA.
    Plug hole theads
    Larry, most automotive machine shops can do that kind of work.
    I had Del's machine shop in Sacramento fix several Porsche cylinder heads for me that had damaged or stripped plug holes. They weld them up and retap them.
    I've put Time serts in Porsche crank cases when the cylinder studs pull out.
    It's been my experience that Time Serts in something like a /2 head, or a old Porsche 356 head with a 1/2" reach tend to loosen because of the heat cycles. I've had better luck with Heli coils in that application, but the best way is to weld them up.
    Ken
    Nov 2006
    Vacaville Ca.
    Thanks Ken . I'll check them out
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    The angle is very important after its welded and re drilled. If it's incorrect the plug wont sit down flush and seal.
