Results 1 to 6 of 6
Thread: F800 ST Manual
    Jun 2012
    Paramus, NJ
    F800 ST Manual
    Can anyone tell me where I can download one?
    does anyone know the torx screw size at the handlebar end?
    thanks,
    Peter
    Registered User Bartleby's Avatar
    Feb 2012
    Omaha, NE
    Try this for the owner's manual. I am told that 2008 is the same as 2007. You didn't specify a year? But by searching around inside the domain (or maybe changing the year at the end of the link?) you should be able to find it.
    http://www.bmw-motorrad.dk/dk/da/bik...00_ST_2008.pdf
    Rick
    Debbie's Servant Lee's Avatar
    SW Iowa
    You could use the Parts Fiche from MAX BMW.
    http://www.maxbmwmotorcycles.com/fic...5&rnd=04302013
    Lee 2011 K1300S
    MOA # 30878
    There's not a manual anywhere that gives fastener sizes.
    Parts fiche don't show wrench size.
    100,000+ miler 32232's Avatar
    Southwestern Ontario
    Don't waste your time getting one Torx wrench. Around here you can get a complete set of lifetime warranty Torx sockets for $20 when they're on sale, or Torx keys for half that. Then you're set for any work or routine maintenance.
    Dave
    '06 Triumph Scrambler (Trans-Labrador veteran)
    Quote Originally Posted by 164809 View Post
    thanks,
    Peter
    It's a TX55. Rarely if ever available as part of a std kit.
