Results 1 to 6 of 6
Thread: F800 ST Manual
    Jun 2012
    Paramus, NJ
    F800 ST Manual
    Can anyone tell me where I can download one?
    does anyone know the torx screw size at the handlebar end?
    thanks,
    Peter
    Try this for the owner's manual. I am told that 2008 is the same as 2007. You didn't specify a year? But by searching around inside the domain (or maybe changing the year at the end of the link?) you should be able to find it.
    http://www.bmw-motorrad.dk/dk/da/bik...00_ST_2008.pdf
    Rick
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    You could use the Parts Fiche from MAX BMW.
    http://www.maxbmwmotorcycles.com/fic...5&rnd=04302013
    Lee
    2016 R1200RS
    MOA # 30878
    Albuquerque, NM
    There's not a manual anywhere that gives fastener sizes.
    Parts fiche don't show wrench size.
    Kent Christensen
    21482
    100,000+ miler 32232's Avatar
    Southwestern Ontario
    Don't waste your time getting one Torx wrench. Around here you can get a complete set of lifetime warranty Torx sockets for $20 when they're on sale, or Torx keys for half that. Then you're set for any work or routine maintenance.
    Dave
    Northern Front Range, CO
    Quote Originally Posted by 164809 View Post
    thanks,
    Peter
    It's a TX55. Rarely if ever available as part of a std kit.
    Ride Safe, Ride Lots
