Results 1 to 9 of 9
Thread: Garmin Express Map Update (Again)
Hybrid View
    Jan 2008
    So Cal
    Did you download the up-date to your computer, as well as the Zumo?
  3. 08-26-2013, 12:18 AM
    Registered User scrape's Avatar
    Silver Spring, MD
    Quote Originally Posted by rockbottom View Post
    Garmin Express doesn't give that option. I forgot that I then have to download Garmin Updater and use it to install the update to the computer. The amazing thing is that rather than fix this glaring bug, Garmin just has its tech support people provide a work around to it.
    Yes it does. It is non-intuitive though. I believe Express has to error out on map install or "not fit" in the GPS memory before it asks if you want to install maps to an alternative location.
    Actually I find the easiest way to install a new map set is to get the alternative install prompt to install everything on the computer only first, so you can see the latest mapset in Basecamp on the computer. Then connect the GPS to the computer so BaseCamp sees it as a device, and right click the GPS in BaseCamp and "install maps" to the GPS.
    Registered User cehlbeck's Avatar
    Apr 2011
    Acworth, GA
    Just 2 weeks ago I bought the lifetime map updates for our 2 year old Zumo 220. Got it from Amazon for not much more than Garmin wanted for a one time update. Of course I got the message that the update wouldn't fit on the GPS (and I only had a 2 GB card added to it also) so I was happy to install just the "lower 49" and all was fine but using Garmin Express it was only installed to the GPS and not BaseCamp. The advanced settings of Express show an option to install to a computer but it wouldn't. It had installed 2014.1 to the GPS. So yesterday I reinstalled map updater and installed the update to the PC with no problem except now the computer has 2014.2 so I'll install 2014.2 to the GPS later. Funny thing is that Express says there is no update for the GPS.
    Chris Ehlbeck
    BMWMOA 168990
    Chris & Donna's Motorcycle Journeys
    Registered User Emoto's Avatar
    Jul 2003
    Boston
    Quote Originally Posted by cehlbeck View Post
    Did you go to the garmin site and activate the card, and also assign it to the GPS unit?
    Eventual Master of the Obvious
    SE Mass - SOHC4 - DoD - BMWMOA - EMOTO #1
    ...proud walking jingle in the midnight sun...
    Free Smugmug Discount Coupon: mStnWv71mNkjo
    Jan 2011
    Spokane, WA
    There has been a fair amount of conversation about Garmin Express on ZumoForums -- http://www.zumoforums.com/index.php
    Garmin pushes you to Garmin Express for map updates from their website but it doesn't work well. Garmin MapUpdater works much better. MapUpdater is less prone to crashing, offers the option to install the mapset to both the computer and GPS in all cases, and is less likely to cause corruption of the downloaded map files.
    For Windows:
    http://download.garmin.com/lmu/GarminMapUpdater.exe
    For Mac OS X:
    http://download.garmin.com/lmu/GarminMapUpdater.dmg
    My understanding is that Garmin Express isn't approved for OEM-branded GPSes (BMW or H-D) and shouldn't be used with those units in any case.
    When I contacted Garmin support earlier in the year concerning a Garmin Express map install issue, the tech suggested I download and hang on to MapUpdater in case it is no longer available at some point.
    When uninstalling Garmin Express watch out for any trash it leaves behind including partially downloaded map updates.
    -Jim
    Agree on the mapupdater software. Just because it says it the newest update does not mean there is major additions or modifications to "ROADS" and streets. Most updates are to things like hotels, gas stations and restaurants. The overwhelming number of roads don't change at all. The bulk of new roads are in subdivisions. So think about what you want. If you are running back roads to do "sport touring" you really don't gain that much. In my experience every time I do a major upgrade, my Zumo starts having issues. It NEVER "just replaces" the old map with a new one. It has to screw something up in the process and make me play with it for a couple days (and a couple calls to Garmin) before I straighten out the problem (which usually is a Garmin software issue).
    Commentary: It used be you could get people who actually knew how the software and maps interacted in MapSource/BaseCamp and your device. Those days are GONE!!!!. Now the tech looks in his database. If, and that's a real big if, they understand what you are telling them there is a small chance you will get an answer ---- if it is in the database. Getting to their second tier is not easy anymore.
    Old But Not Dead
    Semper Fi
