Results 1 to 8 of 8
Thread: How to compression test R60 & R75
    Apr 2012
    Hudson Valley, NY
    Question How to compression test R60 & R75
    Sorry, but I haven't done a compression test in a zillion years, and that was on my old TR6. I tried a search but couldn't find anything....
    I have a 74 R60/6 with dyna electronic ignition. Do I have to ground the plug wires? Or do I just screw in the tester and turn the engine over with the starter button?
    and I'm going to look at a 74 R75/6 with points- same question: what is the procedure, do I have to ground the plug wires?
    Thanks so much-
    Kat
    Yes, I think it would be the best thing to pull the plugs, stick them back into the cap, and securely ground the plug threads to the engine. You should also pull the carbs or at a minimum prop open the slide and/or butterfly on the CV carbs. Not that difficult to just pull the carbs. Engine should have been warmed up.
    I have a gage with a rubber tip so I just stick in the hole and hold it while I crank the starter. But if you have a screw in adapter, just screw it in...finger tight is probably good enough.
    Vancouver, B.C. Canada
    Make one of these with a good used plug. Throw it in your tool box. Comes in handy for testing, tuning and compression testing.
    In situ:
    Quote Originally Posted by happy wanderer View Post
    In situ:
    This is one GREAT idea!!
    Thanks for it!
    Remove the carbs from the heads for the best test. Or at least hold the throttle plates wide open. If air can't get in, it can't be compressed.
    May 2007
    Raleigh, NC
    Nice tool. Much better than the alligator clips I use. Nice post.
    Rob C. , Raleigh, NC
    '10 R12RT, R90/6
    2007 CBR600RR & 09 V-Star
    Suzuki DR 350
    Registered User grover1949's Avatar
    Apr 2012
    Findlay, Ohio
    Thanks!
    Awesome idea; thanks for sharing!
    Apr 2012
    Hudson Valley, NY
    nice! I'm going to try that out. Thanks!
