Results 1 to 15 of 24
Thread: Spoked Rear Wheel, Disc Brake
    No longer a member here
    Apr 2006
    I want to convert my 78 R100S from rear drum to a disc brake. I have all the parts I need, but I can not find a spoke wheel with a disc brake hub???? All there is are snowflakes. Are they THAT rare?
    Administrator 20774's Avatar
    Didn't the early R100RS come with spokes? Assuming it had a rear disk, then they might be pretty rare.
    Fenwick, Ontario Canada
    No, all the R100RSs with spokes had drum brakes, only the ones with snowflakes had the option of drum or disc
    brakes.
    Knights of the Roundel #333
    Apr 2006
    How about the S? I know there was a 1978 R100S with a rear disc. What wheel did that have?
    The same, the only difference is the handelbars & faring.
    Apr 2006
    Does that mean, I cannot get a spoke rear wheel with a disk brake? I have to get one made?
    Why are you trying to reinvent the wheel> pun!
    Not saying it couldn't be done, why don't you just get a pair of Snowflakes with a rear disc.
    Apr 2006
    Quote Originally Posted by Darryl Cainey View Post
    I don't like the looks of the Snowflakes and I hear all these horror stories about them having flaws.
    Only the ones that haven't been taken out of service for the recall. Other than that, they should be fine.
    Apr 2006
    I wouldn't know how to tell black from white. But the main issue is really the looks. The Snowflake wheels to me are an 80s BMW. A 70s Airhead needs to have spoke wheels. Especially a R100S.
    I don't think Snowflakes would look good on a R90S either.
    You might consider calling Woody's Wheelworks and discuss the situation with them. I wonder if you had a rim and hub, could the wheel be respoked with enough offset to allow the use of a disk brake. I suspect some engineering will be needed on the frame side to mount the caliper as well as the master cylinder.
    It's sounding like this combination never existed in production...maybe for a reason...maybe not. But worth a question to some wheel experts.
    Northern Front Range, CO
    Disc on snowflakes only, or aftermarkets (Lesters, etc.)
    Why do you want the disc rather than a drum? If you're looking for the spokes to give that "period authenticity/appearance", i would think that a drum set-up would enhance that look, not detract from it. No?
    Ride Safe, Ride Lots
    You may need to have a hub custom built
    I don't think your going to find a OEM BMW spoked rear wheel or hub to fit your bike that mounts a disc brake, I don't think they made them OEM. I'm almost certain that if there's a Lester rear wheel disc brake it will not be for sale. I know that Morris mags are out there (I have a set for a pending project) and they do make a rear disc wheel for Air heads but you will need to fabricate a caliper mount. Morris mags look almost like Lesters but just a little lighter in weight and a little better looking in my opinion.
    Woodys Wheel Works is an excellent resource and vendor for custom stuff and the staff has a wealth of knowledge regarding what works and what might be a very expensive and unproductive experiment.
    I had given thought to having a disc mounting adapter made for a spoked wheel hub until I compared the stopping power of the rear disc on my R 100S and the drum brake on my R 90/6 and found that there is not much of a difference between them.
    Apr 2006
    At one of the rallies, I saw a R90S with a rear disc brake, that the owner had adapted.
    The main reason I wanted to go with a rear disc was the final drive (imagine that) I found a brand new 32/11 final drive which I would like to install, but it is for a disc brake application.
    Any final drive can be converted over to drum brakes.
