bobframe
I need to use my 1/4" torque wrench in a situation that requires 11Nm of torque. My wrench's range is from 6-32Nm...so it is my preferred tool since my 3/8" torque wrench's dial begins at 20Nm. I am using it to tighten an oil filter and the oil filter wrench requires either a 3/8" square drive or a 19mm socket, which I only have in 3/8". However, I do have a 1/4" to 3/8" adapter that would allow me to use the 1/4" torque wrench.
Anyone see a problem using a 1/4" torque wrench with such an adapter? Obviously the parts all connect and work...but any reason to doubt the wrench's accuracy with such a setup?
Thanks!
Thanks!
