Results 1 to 15 of 21
Thread: Torque wrench with 1/4" to 3/8" adapter
    Registered User bobframe's Avatar
    Jan 2013
    Northeast GA
    I need to use my 1/4" torque wrench in a situation that requires 11Nm of torque. My wrench's range is from 6-32Nm...so it is my preferred tool since my 3/8" torque wrench's dial begins at 20Nm. I am using it to tighten an oil filter and the oil filter wrench requires either a 3/8" square drive or a 19mm socket, which I only have in 3/8". However, I do have a 1/4" to 3/8" adapter that would allow me to use the 1/4" torque wrench.
    Anyone see a problem using a 1/4" torque wrench with such an adapter? Obviously the parts all connect and work...but any reason to doubt the wrench's accuracy with such a setup?
    Thanks!
    We don't take a trip...the trip takes us.
    2016 BMW R1200GSA
    2012 Honda XR650L
    Registered User wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    use the adapter..no issues from my point of view....
    wyman
    ~wyman~
    2015 S1000R - Duke - Black Storm Metallic
    2013 R1200RT - Sassy - Fluid Grey Metallic
    Apr 2006
    it will not effect the accuracy at all, torque is torque.
    2010 F800GS Full Ohlins package, '04 R1100S Replika
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Tuscany and Central Italy 2010
    Jan 2013
    Northeast GA
    Thanks guys!
    2016 BMW R1200GSA
    2012 Honda XR650L
    There is a shade tree method to that one though, I think, and check on this, 1.25 turns after first contact?
    There is a conversion, I think, if an extension is used though, not much, iirc, though
    anyone ever have the wrench re calibrated?
    Sounds like you have the two wrenches I have, a Craftsman and a Harbor Freight
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    As long as the adapter (whether it's a "reducer" or "enlarger" for the square drive) is on the same axis as the drive and the socket, there is no issue.
    It's only when the adapter is offset, or "lengthening", that you need to recalculate the torque value (desired vs. actual applied).
    Oil filters aren't "critical" as to torque (well, at least not for 1100/1150s)... wet the O-ring seal, snug 'er down, firm enough to make sure you'll get a good seal but not so tight that it'll give you grief next time you take it off. And always make sure that the old seal came out with the old filter.
    Apr 2008
    SW Ohio
    good rule of thumb with oil filters is 1/3 turn after it stops spinning freely.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Registered User frenchnew's Avatar
    May 2011
    Prevost (30 miles north of Montreal), Quebec, Canada
    Quote Originally Posted by 35634 View Post
    Sorry there is no rule!
    How much to tighten after the gasket has made contact with the base can and will vary depending mostly on the gasket selected by the filter manufacturer. The gasket will vary in hardness, thickness and shape.
    The best rule is to follow the indication on the fillter, Mann & Hummel oil filter for my RT is a MW75 and it is indicated +3/4 turns after the gasket has made contact with the base.
    Here is some more information on Installation Instructions for Spin-On filters from The Filter Manufacturers Council
    http://www.aftermarketsuppliers.org/...ish/93-3R1.pdf
    Best regards
    2016 K1600GT Cosmic Blue , ABS, ASC, ESAII, TPMS & Alarm, Radio, Sat, GPS Nav V
    Skene IQ150-TS front and IQ 160-TS rear
    Sep 2008
    Wilmington, NC
    Egad- this is as bad as an oil thread.
    My first thought about reaching for a torque wrench to put on an oil filter is to to think about getting someone else with more experience to do the work, before something gets broken.
    There are only two things that matter when putting a filter on- get it tight enough not to leak and don't be dumb enough to strip a thread or get it so tight you need a breaker bar to get it off. Needing a torque wrench to do that suggest the need to pay better attention to Dirty Harry's line " a man has got to know his limitations"
    If you can put the lid on a jar of pickles and not have it leak, a filter is easy...
    Jul 2013
    Solvang, CA
    +1
    Quote Originally Posted by racer7 View Post
    ~wyman~
    Apr 2008
    Consider that the gasket is a big fat squishy rubber ring, then add that it is oiled prior to installation...
    There is going to be a range in which it will seal properly, but not damage anything.
    I have to think that the "spec" is in reality (oh my gosh) actually a strong guideline for "This is about what it ought to feel like."
    Administrator 20774's Avatar
    Quote Originally Posted by JayElDee View Post
    I hope this was tongue in cheek! There is a difference between an adapter and an extension. Use of an adapter...no problem...because the effective length of the torque wrench didn't change. An extension may or may not change the effective length of the torque wrench. If it did change the length, then some math will be needed.
    Registered User k100lt's Avatar
    So. Calif.
    If my filter is leaking how will I know
    David
    1989 K100LT
    Mar 2008
    Camas Valley Oregon
    Quote Originally Posted by k100lt View Post
    That depends on if it leaks internally or externally.
    Marty - in the western Oregon mountains.'06RT, (gone '04RT, '86 Venture Royal, '81 Yamaha Virago920, '82Suzuki GS1100GK, '76 Suzuki GT750, Triumph 750 Bonneville, BSA Road Rocket 650, 61" Harley knucklehead)
    Spring Lake NJ, USA
    Quote Originally Posted by mpmarty View Post
    Since he owns a K brick (where the filter lives in the oil sump) I suspect this was a tongue in cheek comment..
