Results 1 to 6 of 6
Thread: '04 R1150RT Headlight Assembly Help Needed
    Like a dummy, I took all the fairings and body parts off of my RT and now, I can't remember if the headlight assembly had a wing nut or something similar holding it in place on the frame. There is a treaded piece on the back of the headlight assembly which goes into a rubber grommet with metal washer like piece on it that is attached to the metal frame. (see pics) I need help getting Humpty Dumpty back together again!
    Registered User kioolt's Avatar
    Maryland
    You might try looking at a parts diagram e.g. Realoem or Max BMW.
    2004 R1150RT 171,200 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 406,800 BMW miles
    AMA,BMWRA,BMWMOA
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
    Northern Front Range, CO
    Ride Safe, Ride Lots
    Whatever it is, my '02 has been doing just fine without them.
    I don't think I could find them with a sewer snake if they were installed
    My '04 doesn't have any nuts on those either.
    I have mine apart right now too and I had some ducting left over that I couldn't find where it went. Your first pic showed me. Thanks!
    Jim McGill
    '87 K100RS
    '04 R1150RT
    Thanks!!!
    Thanks for your help! I'll be putting Humpty Dumpty back together again soon! Without the nuts, might I add...
