Results 1 to 15 of 30
Thread: Are oilheads more buzzy
    motorcycle cowboy Tennessean's Avatar
    Oct 2005
    East Tennessee
    As the miles add up? My '04 RT has 43k on the clock. This is my first BMW and it seems like it's more buzzy in the seat and grips than when I bought it 8 years ago. Do they get more buzzy or am I more sensitive?
    2013 Goldwing
    Northern Front Range, CO
    43K is still pretty low miles.
    when's the last time you did a valve adjustment and a TBS?
    Ride Safe, Ride Lots
    Oct 2005
    East Tennessee
    In May of this year at 42k.
    2013 Goldwing
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    Typically they get LESS buzzy after they're broken in. At some specific RPM there can be specific imbalances that show up, but between 3500 and 6000 RPM, it ought to be pretty smooth. Not like glass, 'coz it's only 2 cylinders, but not buzzy. Something is asking for a look... If you can isolate at what RPM, what actual road speed, with or without the clutch pulled, what gear, what side (right rear may portend a driveline failure), etc., that should give some clues.
    Left side cam chain tensioner maybe?
    Oct 2005
    East Tennessee
    Quote Originally Posted by beemerphile View Post
    I have not replaced the tensioner as it's not making any noise on start up. Is that a good possibility?
    2013 Goldwing
    Mar 2013
    Winnipeg, MB, Canada
    My 1997 R1100RT gets "buzzy" as well, but, not all the time.
    I live in a place where a day over 75F gets kids out trying to cook eggs on the pavement. Too hot for street hockey I guess. Still a nice day but rather rare. When the temps get above 75F, wow, my riding lawn mower seems faster and run better. I get a very distinct "buzz" at about 3200 to about 3800. It doesn't matter what gear or the road type.
    Below 75F, just even a few degrees, no buzz, horsepower to spare, shifts like an automatic and no "rattle" from the cam chain tensioners.
    I guess what I'm saying is, move to Canada and you won't have a problem?
    I'm looking forward to seeing the weigh in on this string.
    3xR90/6, two just sold, one for a sidecar.
    1983 K100RS for winter project, two K's sold and just acquired a very rough R80RT.
    OldBMWMaster JDOCKERY132445's Avatar
    Sep 2010
    Pleasure Island. NC
    Chain tensioner
    As soon as I installed Tom Cutter's tensioner, everything got quiet.
    Jerry Dockery
    309 N. 3rd. Ave.
    Kure Beach, NC 28449
    1996 R1100RT main bike & 1985 K100RS...too fast to believe.
    FYI- the cam chain upgrade is not a Tom Cutter item, he just sells the OEM upgraded parts as an available kit.
    Upgrading to newer unit it might address the buzz issue, but I tend to doubt it, especially as you say you don't hear it at startup. Easy to check if yours has already been done or not. Earlier design used a 17mm head bolt, new one is 15mm.
    Apr 2006
    What he said, adjust the simple stuff first. TB Sync, always smoothed the vibs. Also surprisingly so did addition of a Techlusion, I actually was surprised at the difference, so I disconnected and reconnected the device to verify that it did smooth it out.
    2010 F800GS Full Ohlins package, '04 R1100S Replika
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Tuscany and Central Italy 2010
    Feb 2010
    Colorado
    Buzz
    Another source (don't ask how I know) is related to wheel damage. I'm guessing that in my case, the cast aluminum wheels are just a little more subject to damage when hitting potholes, railroad crossings, asphalt grinder joints, etc. The damage may not be visible, but just a small amount can add to buzz in the handlebars and seat, and it doesn't matter that the wheels/tires are balanced, you will still get the buzz.
    Piperjim
    '95 R1100RS "Any man who thinks he can be happy and prosperous by letting the Government take care of him, better take a closer look at the American Indian!" Henry Ford
    Retired from riding rad's Avatar
    Santa Cruz
    On my Oil Heads, I've had 5, some did this more than others, I could tell if I filled the oil up past the mid way on the sight glass because of increased vibration. If the oil showed up near the top of the sight glass, I knew this before I ever looked at the sight glass from the increased vibration through my pegs and bars. If I ran with the oil between the bottom of the window and the mid point I had less vibration.
    I also had more vibration if my TPS was not set correctly.
    JohnWC
    Mar 2010
    Akron, Ohio
    [QUOTE I get a very distinct "buzz" at about 3200 to about 3800. It doesn't matter what gear or the road type.
    I too, feel my 96 1100 is more "buzzy" than I thought it would be. I have noticed that when first started, when the engine is still relatively cold, it runs a lot smoother...really nice. Once warmed up, it's noticeably less so. I assume that is because the fuel system is then running it a lot leaner. I also feel that at lower speeds, but higher rpms (3200-3800) the engine seems to be rougher, straining, so to speak. Once at highway speeds, I don't notice it. I have solved this by usually running at about 3000 rpm when not on the expressway. Then it is fine. I was told on this forum that the 1150s have a conterbalancer shaft in the engine that probably solves a lot of this problem. I would almost trade my trusty 1100 to get that, and the 6th gear. But I like the 1100, and I've just learned to live with the less than perfect smoothness. It is, after all, a twin, as has been stated. I can't have everything. And it's really easy to work on.
    Mar 2013
    WOW, I'm loving this stuff!!!!
    Quote Originally Posted by rad View Post
    The oil level thing, you bet and I can't rationalize why. Me bad one day, a bit too enthusiastic and I over-filled my own R1100RT by about a cup and got a buzz. I looked for a reason for a long time and didn't think about the last thing I did to make a change in the bike, the damn oil change and over-filling it. Next oil change, more careful, nice rainy afternoon and the right oil volume, buzz is gone. Explain that to me with with an Excel spreadsheet.
    jconway607, we have lots of days below 75F and last I knew, we still like our neighbours (that's the Canadian spelling version). Move here and avoid having to shell out the coin on another bike that has it's own issues. 6 gears would be nice though.
    I have an '81 KZ440 LTD that was a basket case. In cooler weather, the little girl is massive fun. A little warmer and it gets harder to start. The choke even needs to stay on longer. It "fuel loads" on one cylinder on start and takes a block or two to really want to run nice. I have done everything two or three times and the only conclusion is that I may have a valve stem that changes shape a bit. Yeah, that's a stretch but I don't have a wideband oxygen sensor to worry about. I don't worry about fuel economy because it's fun to ride.
    Ambient air temp has always been a given that it affects an engine and sometimes, big league effect. Just ask the long haul guys that spend thousands on wrapping their intakes and exhaust with blankets. Keep the air cool going in and cool going out, and you can create a different animal.
    Oct 2011
    Florida & Massachusetts
    Quote Originally Posted by pffog View Post
    Not so surprising that the Techlusion would do that.
    Vibrations and buzz can come from several sources which others have commented on. Power/torque imbalance buzz can sometimes be improved by an AFR (air fuel ratio) balance which means balancing the air side to side, and the fuel side to side. BMW solved the fuel balance problems on the R1200 Hexhead and Camhead with dual O2 sensors and independent cylinder software Adaptation.
    On R1100s and R1150s, a TB balance done well will usually result in balanced AFRs. But if the injectors are mismatched through aging or otherwise, no amount of TB balancing will fix the problem. When you add fuel, as with a Techlusion, you can get to the point where you've added enough to consume all air in the cylinder charge. That will get the power/torque back in balance.
    Although the Techlusion has been around a while it has three drawbacks: it's an Open Loop solution, the Motronic shifts to limp home fueling pattern and it has four adjustments, none of which have a specific, known effect. Now there are two lambda shift devices available that add fuel Closed Loop, with only one adjustment, and in specific, known amounts: Innovate Motorsports LC-1 and nightrider's BMW-AF-XIED.
