Results 1 to 8 of 8
Thread: 04 GS ADV couple questions.
    Sep 2006
    Attica,OH
    Just bought last week 04 GS ADV, like it a lot so far. First question is, the high beam head light was not working at first thought it was burned out, but after taking it out and started to look around found a wire came on plugged. Works know, but the light is of one never seen before, the Clymer calls for a H1 bulb but its not, started to check around and found it is a high dollar one, don't know the size. The pictures show what it looks like, and don't know how to get the black wires out of the rubber boot it goes through, in the picture with out cutting it. So my questions are what type of bulb, how to get the wires through boot and can you change it to a H1. And also it has a one piece seat, can a two piece seat fit on it from other R1150GS. Thanks.
    Canada and the Alps
    The standard bulbs (low and high beam) in a R1150 GS Adventure are H1. I would know having replaced both last year.
    I can't make much out from your pics, but it looks like someone installed an aftermarket kit of some kind...just a guess.
    Apr 2010
    Vancouver Island BC
    You're correct that it is an HID bulb. A picture is worth a thousand words so I'll just post an excellent link from advrider on how to convert from the OEM to HID and let you take your time to reverse engineer it. Shouldn't be a problem aside from the slightly larger hole that may have been drilled in the back of the plastic housing....you'll see what I mean. There will also be two ballast (if both lights were done) to take off.
    http://www.advrider.com/forums/showthread.php?t=388828
    There are also several threads on that forum on the seat issue.
    '64 R50/2 - "Gone But Not Forgotten"
    '76 R90/6
    '02 R1150GS Adventure
    Northern Front Range, CO
    Sure looks like a HID to me.
    why would you want to change it to anything else?
    Ride Safe, Ride Lots
    Sep 2006
    Attica,OH
    Thanks for the reply's & link, not sure if I will change it back. It is real bright at night. I was just skimming through the link and didn't see what the bulb size, would like to find the size just in case I would have to replace it. And if anyone knows if you can use the two piece seats on the bike, because the seat isn't the most comfortable, was thinking about getting a daylong for it, hopefully finding a used one, have one on the 04 Rt and like it a lot. Thanks
    fwiw, in close to 80K miles and 8 years of usage, I have yet to replace any component in my HID systems.
    as already stated, stock is an H1.
    http://www.maxbmwmotorcycles.com/fic...1&rnd=04302013
    Sep 2006
    Attica,OH
    When I was putting the bulb back in the head light globe, it was a tight fit and I must have put the wrong stress on it, it putt a hair line crack in the bulb, so I'm thinking it might go out sooner then most.
    Canada and the Alps
    Why would you want to change it to anything else?
    If it is plug 'n play I wouldn't have an objection to changing to HID, but as someone already stated in this thread, some grinding of the plastic housing is required. Sort of like batteries that do not have the correct posts on them. Why don't they just make things that are standard?
    One advantage of a light bar and auxiliary lighting is that you have redundancy as well as having common bulbs that are easily sourced.
