Results 1 to 13 of 13
Thread: Garmin Zumo 660LM Fuel Gauge Issue
    Raffa
    Aug 2012
    Arcata, CA
    Hello
    I purchased a new Zumo 660LM at the Salem Rally and used it on the remainder of my trip. I don't seem to be able to get the fuel gauge to operate properly. I read the manual and set it up as directed; however, the warning appears at different mileages and the visual warning only flashes on the screen and there is no audible warning. Tech support was not of any help. Anyone else have a similar problem?
    thanks in advance for the help.
    Riding where it's hot! AZ-J's Avatar
    Mar 2007
    Scottsdale, AZ
    You have set two values, total miles and how much advance you wish to be warn.
    Om my R1200S I set #1 to 190 (even though I can go 10-15 more) and 40 warning. This gets it correctly every time.
    My bike shown here
    Jordan M, MOA #24434
    My Blog
    Raffa
    Aug 2012
    Arcata, CA
    Gas Gauge Issue
    Joordan
    I set "Distance Per Tank" at 200 and "Low Fuel Warning" at 195. Iss that correct? You indicated you set the second miles at "40". Am I misunderstanding the way the warning works? I feel pretty ignorant at this point.
    Mar 2007
    Scottsdale, AZ
    Low fuel warning should be 40-50 not 195 or you'll get notice 5 miles into riding.
    My bike shown here
    My Blog
    Canada and the Alps
    Quote Originally Posted by ralphmccomb View Post
    Does your BMW model not have a bar graph fuel gauge and warning light?
    That is all I use on mine and I can easily trust it down to 2 liters of the 30 liter capacity.
    And if not the on-board fuel gauge, the trip odometer works quite well.
    Mar 2007
    Scottsdale, AZ
    My BMW does not a fuel gauge. It has a 50 miles countdown to empty that is not as accurate as a Garmin unit!
    The Garmin gauge is dead-on once set correctly, and it'll point you to fuel stations once a warning is on.
    My bike shown here
    My Blog
    Canada and the Alps
    Quote Originally Posted by AZ-J View Post
    What model of BMW cheaped out?
    The Garmin gauge is dead-on once set correctly.
    I highly doubt that. How does the Garmin know what your engine loading is?
    Mar 2007
    Scottsdale, AZ
    The model is a 2007 R1200S and most do not have a fuel gauge because to have one required the PC and most do not. I have engine temp, and gear. And occasionally, a 50-0 count down.
    The Garmin has proven more accurate with my guesses on range (190) and warning (40 or 50). That it points me to the nearest fuel stations that whole time is priceless, too.
    My bike shown here
    My Blog
    Canada and the Alps
    The model is a 2007 R1200S and most do not have a fuel gauge.
    In that case, it is understandable that anything else might be more accurate. No fuel gauge? Dumb or what!
    Without a fuel gauge, I could go on past fuel burn history (my Excel fuel consumption history spreadsheet shows a very narrow range) using my trip odometer.
    Administrator 20774's Avatar
    Quote Originally Posted by GlobalRider View Post
    I have been keeping Excel records on my /7 since I got it in 1980...obviously no gas gage. I know within probably 0.05 gallons how much fuel is in the main tank. When I hit the first indication of needing to go to reserve, I do a quick mental calculation of fuel mileage. Knowing also reasonably well how much fuel I have on usable reserve, I can then quickly calculate miles to empty...I'm then looking at the map to figure where my next gas stop is. But it does take cumulative history to be able to do that.
    It also lets me know if the engine/carb performance is within normal bounds.
    Canada and the Alps
    Here is a trick for GS airhead riders with dual petcocks.
    When my engine stumbles indicating a need to switch to reserve, I note my mileage, switch my right petcock to reserve and my left petcock to off. The right side of the tank is smaller due to the electrics (ignition module, voltage regulator, relays) under it. When the engine stumbles again, I note the mileage gone since switching to reserve, I switch my right petcock to off and my left petcock to reserve. I can now go at least that same distance again since there is more fuel on that side of the gas tank. As for the gas sloshing about in the gas tank, well that is minimal and if it does quit on me, I can switch the right petcock to reserve and whatever sloshed over to that side will get me up someone's driveway...it never came to that.
    Fuel management...from my flying days. Mind you, we never cut it that close.
    Also a reason I do so.
    Alex -
    This getting a bit off topic, but I do exactly the same w/ right/left petcocks. I know how much fuel I have in each tank saddle. To get the last of the fuel, the tank can be removed and tilted to get all the fuel to one side...might get another 5 miles. But it has never come to that!
    Mar 2007
    Scottsdale, AZ
    You are being stupid not understanding that most R-S models did not want a trip PC with TPM and assorted garbage. Most were track models. Only 4K came into the USA and there a few hundred left!
    My bike shown here
    My Blog
