Results 1 to 12 of 12
Thread: This is a GPS/Scala question combined
    the-oz-slider
    Apr 2010
    Edmonton Canada
    Cool This is a GPS/Scala question combined
    I run a Garmin 660 and a Scala Q2 package on my Shoei Neotec/2007 R1200Gs and I want to be able to listen to regular FM radio [for the weather forecasts as well as the variety], rather than always listening to my ipod. The Scala claims to have preset FM stations on it, but they are simply terrible in our neck of the woods...
    Does anyone know what I need to do/buy to make it all work? I was told there is an add-on for an ipod that acts as a radio receiver and allows the full spectrum of FM stations to be received loud and clear....then I read somewhere else that this product is discontinued.
    In lieu of the following, is Sirius XM radio on a bike viable?
    Worse case I have a set of old Datsun speakers im gonna mount on the top of the screen with fencing wire and hook 'em up to an 8 track I found somewhere. I also have an old His Masters Voice bakelite brown radio with the fabric cover over the speaker I can use if needed.....
    Thanks, serious comments or those in jest will be appreciated........
    Al
    Jan 2011
    Spokane, WA
    One idea...
    You can search for other (not preset) FM stations with the Q2. Press Volume Up or Volume Down for three seconds to start searching to higher or lower frequencies. Once found, a station can then be saved as a new preset. Check out the "Working with the FM Radio" section in your Q2 manual.
    Good luck!
    May 2013
    Quote Originally Posted by 155767 View Post
    I run a Garmin 660 snip In lieu of the following, is Sirius XM radio on a bike viable?
    XM on a bike is very viable. Your Garmin model should do it I think. My 550 does XM with an optional ext antenna, and it does it very well. There are attachments for the garmin mount that incorporate the antenna too.
    I have been WAY less than impressed with XM weather on the Garmin, and the traffic service is so so, but those are additional options using the XM bandwidth.
    You will have to pay for another subscription, the interface is decent, the reception is pretty good. You will NOT get local stations though thru the XM.
    John
    Jan 2011
    Spokane, WA
    I think the Zumo 665 has XM capability but the 660 does not.
    It's a way of life! oldnslow's Avatar
    Oct 2011
    Ash Grove, MO
    My FM reception on my Q2 set sucks no matter what, and I live within 20 miles of all the stations in my area. I think the lack of an antanea is the problem. I'm considering this for my bike. It has weather, and inputs for mp3 and output for headphones. I will just run a headphone wire to my headset from the radio. I don't run a GPS on my bike.
    http://www.amazon.com/Jensen-Radio-J.../dp/B0025POKOA
    Mike Davis
    "Old n Slow" It's a way of life!
    1985 K100RT
    1998 R1100RT
    Feb 2004
    Monroe La.
    I bought the Scala G9 earlier this year. Have not had any issue with the FM radio when used. I like the Bluetooth using my Nano.
    1975 R90/6, 1980 and 1982 R65, !959 TR3A Triumph Car
    Sep 2008
    Wilmington, NC
    You'll be better off with Sirius if you want both reliable reception and a range of content.
    There are two realities for FM radio
    1) Unless you're smack in a large urban area you are not in range of much content. And even then, see below, strong stations will stomp all over the weaker ones that you might want to hear.
    2) That is partly because modern FM receiver design is cheap junk with very poor sensitivity and selectivity compared to older heterodyne circuit sets of 40 years ago. The last time I checked the only reasonably competent consumer FM radio one could purchase was the GE Superradio and that was about a decade ago- and its a tabletop model.
    The FM receiver on Scala is there as a marketing item and is worthless outside of an urban area- got all the generations and don't waste my time with the FM feature.
    Years ago when there was still some decent FM content I had an antenna with beam capability on my chimney 40 ft up hooked to the best existing stereo receiver- I got one or more stations on every FM channel in SE rural NC and could routinely listen to stuff from mid VA to GA. I don't bother these days..
    the-oz-slider
    Apr 2010
    Edmonton Canada
    Scala fm
    Ok, I'll complicate things by suggesting that having both fm and am would be good, then I get coverage all over and can listen to whatever I want, including all the sports and political crap.....
    the-oz-slider
    Apr 2010
    Edmonton Canada
    Radio
    Ok,
    I saw a Jensen brand waterproof radio for sale on fleabay, and it claims to be ipod compatible, soooooo, if I buy that radio, and hook it into my ipod, which feeds into my Garmin 660/scala, does anyone have any experience with these Jensen radios in that scenario by any chance, please and thank you.......????
    I t
    Have given up trying to get decent reception out of my Scala on the FM radio mode....in my area its just hopeless.....
    Or if there is another option I'd appreciate commentary..
    Al
    Ed Kilner #176066
    Nov 2011
    Mississauga, ON
    This is a systems integration problem. I searched for Jensen Radio, found one, and:
    Front panel audio AUX-in for use with iPods, MP3 players & portable CD players
    3.5mm headphone jack pigtail & 2-channel stereo speaker output
    So, If your Scala has a wired input jack, you could connect the Jensen so it plays to the Sena. Then, you could wire an iPod to the Jensen. As I read it, the Jensen should pass the iPod audio through to the Sena.
    Lots of wires.
    Don't see any mention of Bluetooth and that would be a more problematic issue requiring at least one of the items to have multiple bluetooth channels. There. is a Sena hub that has this feature, and my new iPod Nano was bought to connect to my Cardo via Bluetooth.
    So, good luck!
    Ed
    2015 R1200RT; 2011 R1200RT RIP; 2000 Triumph 900 (sold)
    http://triumphantsblog.blogspot.ca/
    Sep 2008
    Wilmington, NC
    This isn't the 60s. The high power AM stations of that era that one could receive in large areas of the country at night are essentially gone.
    AM, like FM, is low powered stuff these days though with perhaps a bit more range the FM. Anyway, my comments about receiver design and quality still apply- there is no such thing as a high sensitivity and selectivity AM receiver small enough for your bike.
    the-oz-slider
    Apr 2010
    Edmonton Canada
    Radio
    Thanks for the input....bad pun......
