Results 1 to 10 of 10
Thread: Sena SMH-10 - C3
    Oct 2012
    Sena SMH-10 - C3
    Been reading all the threads on BMW Bluetooth and quality of helmet headsets. From what I have read, the Sena SMH-10 seems to work the best when properly paired.
    My question is, is there a problem attaching the SMH-10 to a C3 helmet?? I have read that it is an easy fit to other helmets but before I purchase I need to know if I am purchasing a bitch to install.
    Registered User frenchnew's Avatar
    May 2011
    Prevost (30 miles north of Montreal), Quebec, Canada
    You will need to use the double side adhesive to secure the bracket to the helmet as the clamp does not work well with the Schuberth C3 helmet.
    The adhesive is really secure if you cleam the helmet surface properly (I have installed mine 2 years ago and no problems yet).
    2011 R1200RT Triple Gray, ABS, ASC, ESAII, TPMS & Alarm.
    Wunderlich Engine and Rear Prot. Bar, Oil Cooler Guard, CSS Tank Pads, Paralever Slider, Mirror Adapters & Flash Mirrors,
    Integrated GPS Mount & Touratech Zumo 660 Locking Mount, Russell Day-Long Seat.
    Oct 2012
    Thanks for the quick reponse. Was there any issue with the operation of the sun shade or is the Sena unit attached farther back?
    Did your Sena pare well with the bike?
    Cowboyatheart
    Feb 2009
    Pender Harbour, B.C.
    I have the Sena on a BMW system 5 (or 6?) helmet. Used the adhesive with the optional base that has the microphone on a wire. The boom would not fit because I had to put the base further back on the helmet because of the sunshade slider. The microphone I velcroed to the front of the check pad so it did not interfere with the flip of the helmet. Works really well. Paired with iPhone or with my garmin 660.
    Moringa, your body & brain will thank you! PM for discounts Smart Mix at TasteMoringa.com
    XM3 Energy, real energy for the body & brain, no sugar high, XM3.Energy
    Mar 2007
    Chicago, Ill
    Sena offers a specific 'clamp' that works with the C3
    http://www.senabluetooth.com/product...ab_menu=helmet
    The mic is cleanly mounted inside the helmet and the base adheres to the helmet. Very slick mount and not expensive - the original clamp holds the jog dial at an awkward angle and creates wind noise due to the design of the helmet. Does not interfere with the sun visor operation.
    May 2011
    Did not have an issue as I used their SMH-A304 for my in-ear phones which I prefer over their thin sounding speakers and I get a bit of noise isolation which permits me to lower the sound volume.
    I do not pair with the bike as I do not have the on board sound system, instead I have a Cowon J3 MP3 player and an Iphone 5 and they work well.
    I believe that even with the SMH-A302 you will still need to use the adhesive pad to install as the bracket does not change, this adapter only offer an attachable microphone.
    Quote Originally Posted by scalese01@verizon.net View Post
    Central Ohio
    Quote Originally Posted by Beemer01 View Post
    Thanks for the link, I was about to go take pictures of mine. I'd like to emphasize to the OP that you need the Universal Microphone Kit.
    cowboyatheart: The cheekpad mount sounds interesting as I get tired of fussing with the mike every time the helmet goes on. Any problems being heard clearly with the intercom or phone?
    Larry
    2006 R1200RT
    Nuckin' Futs! tonyfr's Avatar
    Apr 2007
    SAT - LAX
    Quote Originally Posted by cowboyatheart View Post
    I use the adhesive base and the boom mike that attaches with the wire, not the wired mike. I just put the velcro tab under the cheek pad and extend it to the front of the chin bar. Stays in place when I raise the chin bar and the base is mounted just behind the sunshade slider.
    SABMWRA MOA #62
    2005 BMW R1200RT
    1984 Kawasaki ZX750-E1 Turbo
    Aug 2012
    Grand Rapids, mi
    I have the c3 pro - with the sena SMH-10. Works very well - but get the version with the detached boom mic vs. the one where the mic attaches directly to the exterior bracket. I believe the model is SMH 10-11.
    http://www.revzilla.com/motorcycle/s...#activate_zoom
    I use it with foam earplugs when on the highway and it works fine - excellent pairing with an iPhone, and nice sounding music. Good battery life - I road six solid hours in pouring rain and the unit worked flawlessly (more than I can say for my rain gear).
    Jul 2007
    THE BIG SKY
    I've got about 30K miles on a C3/Sena outfit. The previous posts have provided the needed details. I use the adhesive option to attach the mount to the helmet and the boom mike that is detachable. I also prefer the ear bud option over the speaker set-up.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
