Results 1 to 5 of 5
Thread: 2008 GS transmission lubrication
    Jun 2011
    Need some feedback. Bought an '08 GS with 5200 miles and we are now sitting at 26.7K at present. I have been religious about maintenance. At the last "major" / 24K the guy that does my major services (not a dealership), but a BMW / KTM guru; told me he didn't like the color of the transmission oil. We agreed to check it after my latest trip...now 2500 miles later we check it again and again he thought the transmission oil was too discolored. He claims it has too much metal in it? Bike runs and shift great. Does this model year have known bearing issues or am I dealing with a overly paranoid motorcycle mechanic? Using Spectro.
    #13338 PGlaves's Avatar
    The answer depends on what the oil actually looks like. Metal on the magnetic plug is a bad sign. Some metallic sheen on the oil might be bad. Muddy looking probably just signals some grease being washed out of the sealed bearings into the gear oil. This is typical when synthetic gear oil is used.
    Mar 2013
    Walnut Creek, CA
    Can't comment on the year but if you are concerned, change the oil and send it out for particle analysis.
    2007 R1200RT-P
    Jun 2011
    thanks...makes sense. No particles on plug...no sheen on oil to speak of...just a bit muddy...just barely. Spectro full synthetic is being used.
    Quote Originally Posted by ntlost View Post
    I have seen several cases where fresh, new, synthetic gear oil turned a muddy brown in only a few hundred miles as grease washed out of the sealed bearings. I would keep my eye on things (change oil next engine oil change) but wouldn't worry about it much.
