Results 1 to 14 of 14
Thread: 07 R1200RT-P parking light bulb
    Mar 2013
    Walnut Creek, CA
    I give up. How do I get to the damn bulb?
    I've removed bodywork. Replaced main headlight bulbs.
    Removed mirror assemblies.
    Tried removing speakers (solid behind there).
    Still no obvious way to get to those bulbs. This is driving me crazy and my hands are bloodied and scraped to heck.
    2007 R1200RT-P
    Mar 2013
    Walnut Creek, CA
    I'll answer my own question.
    The mirror assembly (plastic and glass panel) pop off easily, which is why they sell tethers to hold them in place.
    You do NOT want to pop the glass off the mirror mechanism, which I did on one side (shattering the mirror).
    Once the mirror assembly is off, at the top you will see two torx screws, which hold on the "nacelle". That's French for "which German $#%# engineer came up with this system?" or in English the small pieces of bodywork atop the signals.
    With these removed, you will see the parking light wiring and holder. Rotate about 45 degrees and it will pop out, pull the bulb and replace.
    I'm learning...
    2007 R1200RT-P
    Clovis, NM
    Because I don't want you to think no one reads your posts, I'll respond.
    Correct.
    Couldn't respond yesterday because I was working....
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
    Mar 2013
    Walnut Creek, CA
    Hahaha. Thanks Steve. I swear changing bulbs on this bike has got to be the most complicated repair job (so far).
    2007 R1200RT-P
    Mar 2013
    Walnut Creek, CA
    On the topic of bulbs, BMW calls for a W5W.
    That would be a #194 bulb, but other posts here or in another forum recommended the use of a #168, which is slightly brighter as it draws a tiny bit more voltage.
    I went with an amber bulb for visibility, and the new bulbs are not as bright as what was in there (well, the one working bulb). Not sure if this is because of the amber, or because the info about the #168 being brighter is incorrect.
    Whatever was in there is unmarked, and I have a feeling if I replace these again, I'll go LED.
    2007 R1200RT-P
    Albuquerque, NM
    Quote Originally Posted by danix View Post
    That would be a #194 bulb.
    Actually, the entire world save for the USA calls them W5W.
    The owners manual for my 2012 has instructions for replacing park light bulb.
    So does the owners manual for the OP's bike. The fact it's an ex-Police bike makes no difference and the OP can still order an owner's manual at a BMW dealer.
    Kent Christensen
    21482
    Mar 2013
    Walnut Creek, CA
    I did check the manual - perhaps the year was wrong, but what they described (removing the mirror) was for the turn signal bulb.
    2007 R1200RT-P
    MOA #148075, BMWRO Shaun09's Avatar
    Mar 2009
    Eugene, OR
    After going through a pair of inexpensive amber LED wedge bulbs from Autozone, I got a pair of these from PIAA: http://www.piaa.com/store/p/179-168-...gen-Bulbs.aspx.
    There are similar products that may cost less: http://www.superbrightleds.com/morei...edge-base/197/.
    Hope your hands heal. Cheers!
    Chris
    2009 BMW R1200RT (Shaun), 2004 MINI Cooper S (Gromit), 2006 BMW X3 (Wallace)
    Sep 2008
    Wilmington, NC
    Parking bulbs are one thing but you need to be awareof another BMW difference should you think you can randomly sub LEDs elsewhere.
    Your bike has a central computer system that monitors current draw and serves as automatic fuses (which is why it has no traditional fuses except what might be there for add ons). Called by it's German abbreviation, the ZFE will display an annoying "bulb out"" alarm on your dash with many types of LED substitutions, unless the bulb or device in question is designed to mimic the current draw of the original bulb or is close enough not to trip the unpublished monitoring limits of the ZFE. Unless you're willing to reseach bulb alternates carefully, its best to stick with oem types or the US equivalent number. (My 08RT is using a halogen parking bulb which is brighter because it is more efficent at the same current- but those bulbs are hard to find and perhaps currently unavailable).
    Mar 2013
    Walnut Creek, CA
    Ah yes, similar to the headlight monitoring system used in many Audis back in the day.
    Thanks racer7, will definitely keep that in mind.
    2007 R1200RT-P
    Rocky Bow BMW Riders #197 bogthebasher's Avatar
    Apr 2008
    Calgary AB
    That is the correct procedure. First remove the Mirror (pull it off) then the triangular piece of painted tupperware held by two Torx T25 screws. This reveals a rectangular access port to get at the bulbs (small hands are of value here). You may need a flashlight to see the socket but at least they thought ahead and there is a handy lever on the socket to help get them out. Fish the socket and wire out the hole, change the bulb and put everything back the way it was. I changed both bulbs - the first lasted 70,000 Km.
    P.S. I substituted with a #194 available at Auto Value stores in Canada for $0.94 CAN each. Their part number was WKO194.
    Ken Dittrick
    2008 R1200RT (Biarritz Blau)
    Excuses are the rocks upon which our dreams are crushed - Tim Fargo
    just wait
    now that you've learned to change the parking bulb ( with frustration) just wait until you try putting in a new left side low beam headlight.
    Mar 2013
    Walnut Creek, CA
    Believe it or not I got all the headlight bulbs in OK (with skinned knuckles and lots of small cuts!)
    2007 R1200RT-P
    Apr 2008
    Calgary AB
    Yeah, me too. Nice job!
    Ken Dittrick
