Results 1 to 11 of 11
Thread: New member - '03 K1200LT Headlight / Satellite Help
    Registered User JD Hilton's Avatar
    Jul 2013
    Muscatine IA
    I am new to BMW MOA. I wonder if anyone can tell me what the red light below the headlight adjustment on my recently purchased 2003 K1200LT? My previous ride was a 1985 K100RT that Mother Nature decided to smash.
    Jul 2013
    Muscatine IA
    New Member, Navigation question
    Could anyone help me figure out why my navigation can't find satellites? I did a reset and it kept saying it was searching for satellites.
    Welcome to the MOA and the forums!
    A photo of the red light may help answer that question, and perhaps the model of your GPS might help answer that one.
    Apr 2009
    Huntersville N.C.
    The red light is for your alarm system. When you shut the bike off the number of times it flashes is the number of remotes the bike is setup for.
    Dave
    2004 Black LT
    2000 Canyon Red LT
    Jul 2013
    Muscatine IA
    photo of gps
    Gps is garmin street pilot color map
    OTE=deilenberger;890043]Welcome to the MOA and the forums!
    A photo of the red light may help answer that question, and perhaps the model of your GPS might help answer that one.[/QUOTE]
    Registered User cehlbeck's Avatar
    Apr 2011
    Acworth, GA
    Being the owner of a 2002 K1200LT and having both those features I know the answers.
    The little read light is for the alarm. I turn mine off and it blinks twice (even when not armed) once for each remote. It will then blink after a number of seconds to indicate that it is armed. It the bike is disturbed, it will also blink for the number of times the alarm is triggered. You can also set the alarm to auto arm when the motorcycle is turned off or to be manually armed with the remote (setting "B" I believe). There are instructions in the alarm booklet for doing that.
    The GPS. It's a BMW Nav I which is a Garmin Street Pilot III. I had it on mine. It's no longer supported by Garmin and updates are no longer available. Before replaced mine 2 years ago, it would sometimes take FOREVER to obtain the satellites. It always took forever to recalculate. But if you ended up getting the MapSource CDROM and computer cable, you can create routes on your PC and send them to the GPS. You'll need the little Garmin lock tool to get it off the motorcycle though.
    Oh and by the way, my warning sticker about the ABS Servo Assist brakes looks just like yours!
    Chris
    Chris Ehlbeck
    BMWMOA 168990
    Chris & Donna's Motorcycle Journeys
    Jul 2013
    Muscatine IA
    Thanks for the info
    Thanks for the info on the light below headlight adjuster, (alarm is disconnected and no key fob came with the bike) and thanks for info on gps.
    J.D.
    1985 K100RT (my first BMW, felled by a tree)
    2003 K1200LT
    Jul 2013
    Muscatine IA
    gps mount
    Quote Originally Posted by cehlbeck View Post
    Chris
    Is there any gps that uses same wiring as the factory original?
    Is there any gps that uses same wiring that came from factory? Can you post picture of yours?
    J.D.
    2003 K1200LT
    Apr 2011
    Acworth, GA
    Oh this GPS uses a remote antenna and there is no internal antenna. The antenna plug is different from the power plug you can see on the upper left of the GPS. It's a metal "turn once" to connect and without it the GPS won't see the satellites.
    There was a GPS or two after it that could be made to work with the existing wiring and intercom but nothing current. We went to Bluetooth headsets and I just replaced the old GPS with a Garmin Zumo 220 when I did.
    I notice the 2nd antenna too. Does your CB work? I could never get that old Midland to work even after I replaced it. The CB will only work through the intercom and helmet speakers and not the fairing or top case speakers.
    If you haven't found it yet, you may want to head over to bmwlt.com too as there's a wealth of knowledge over there about the K1200LT and I know GPS comes up all the time. Just don't ask about what oil or tires to use!
    Chris Ehlbeck
    BMWMOA 168990
    Jul 2013
    Muscatine IA
    Previous owner kept the CB, so 2nd antenna is ornamental. I removed gps and zip tied wires to the metal mounting bracket.
    J.D.
    2003 K1200LT
    Jul 2013
    Muscatine IA
    update on navigation
    Stumbled across a Garmin Street Pilot Color Map identical to factory model. It had antenna and memory card, and all the cables for pc. Turns out my brother in law had one given to him a couple of years ago. Yeah, that made my day in a big way!
    J.D.
    2003 K1200LT
