Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: Neglected R100GS/PD
    Canon City Colorado
    Neglected R100GS/PD
    Just purchased a 1995 R100GS/PD Classic. It only has 6,366 miles on it but has been sitting in a garage for 10 years or so. Of course the previous owner did not drain gas or do anything to it other than park it and cover it up. Working on it, I am interested in a battery. . .any comments on lithium or suitable replacement. Also, a gas tank bag and rear trunk. The back rack is chrome but has a lip on it. Not sure if there is a after market trunk for that model. I am sure you guys would know. Thanks for the help and anything I might over look besides the obvious fluids to replace on this fine model to bring it back to life.
    Nov 2005
    Calgary, Alberta
    You'll get various replies on preferences for battery type, but I would get a flooded lead acid.
    Rinty
    2011 R1200RT ka5ysy's Avatar
    Oct 2006
    Prairieville, Louisiana
    Sounds like a good project bike. How about some photos ?
    MSF #127350, Instructor, Louisiana Dept of Public Safety
    Motorcycle Safety, Awareness & Operator Training Program
    NAUI Instructor #36288, Board Member, Divers Alert Network
    BMW Motorcycle Owners rdalland's Avatar
    May 2006
    of America
    Quote Originally Posted by RINTY View Post
    My Dakar spends a lot of time on it's side...I opted for a sealed gel battery so I don't have to worry about battery acid.
    ride what you've got; enjoy the ride!
    Reid - Stone Ridge, NY - BMWMOA #69187 - Turbo Fluffy Motoclub - IBA #50182
    Registered User beemerguru's Avatar
    Foster City, CA
    GEL MAT...but the battery is just the start, You'll need a carb rebuild, steering head bearing re-greasing or replace, throttle mechanism grease, all the fluids changed, possible master cylinder replacement, check tires for date of manufacturing - air will need to be replaced, check electrical connections for corrosion, make sure rear brake shoes aren't frozen, check air filter for mouse nest....and then you can start with a standard tune up.
    kidding about the air ;-))
    Greg Hutchinson
    R80G/S (4) 633CSi with 450K mile
    '68 R60/2 '88 K100RS Special Edition
    http://gregsgssite.shutterfly.com/
    Do not neglect the wheel bearings. When I purchased a "well maintained" bike, the front bearing was totally dry! Cost me dearly!
    After weighing all the options, my top two choices were ones either from Advance Auto (guaranteeed 1 year) or Batteries Plus or AutoZone.
    the others were expensive and not worth the extra cash in my opinion.
    Also there are zillions of AutoZone's/Advance Auto stores no matter where you travel.
    No longer a member here
    My battery preference generally for ALL my bikes is AGM - Absorbed Glass Mat. Westco has a full line and batteries for almost all BMWs. Discharge rate is very slow and they can be installed in any position. The advantage over Gel batteries are: AGMs are slightly less expensive and they do not need a special charger. Disadvantage over conventional wet batteries are: AGMs are slightly more expensive (which is more than compensated by longer life) and they do not tolerate a deep discharge. I have a Westco AGM in my 77 R100S, my 90 K1 and my 99 R1100RT. My K1600GT still has the factory Gel but will get an AGM as soon as it needs a new battery
    Registered User mysteriousfish's Avatar
    Feb 2011
    Portland, Oregon
    Quote Originally Posted by beemerguru View Post
    GEL MAT...but the battery is just the start, You'll need a carb rebuild, steering head bearing re-greasing or replace, throttle mechanism grease, all the fluids changed, possible master cylinder replacement, check tires for date of manufacturing - air will need to be replaced, check electrical connections for corrosion, make sure rear brake shoes aren't frozen, check air filter for mouse nest....and then you can start with a standard tune up. kidding about the air ;-))
    ++ on the airbox...I bought an R100 that lived on a farm and there was a mouse nest in the tail cowl; mud daubers nests behind the side covers, and the air box intakes were choked with bird feathers!
    michael
    __________
    1995 R100GS; 1994 R100R
    Canada and the Alps
    Quote Originally Posted by podsobinski View Post
    I just brought my R100 GS out of hibernation. It has been parked since 2002 and it needed a battery.
    I usually go for the factory BMW Mareg batteries, but cost and a direct fit replacement had me try a YUASA 53030. I hope it lasts as long as the factory BMW batteries that I always got 9 years out of. These are plain old flooded lead acid batteries that can be maintained, which is why they last.
    Other battery types such as AGM, GEL and Lithium are too finicky. They do not do well in hot climates because the charging system generally overcharges them.
    I Other battery types such as AGM, GEL and Lithium are too finicky. They do not do well in hot climates because the charging system generally overcharges them.
    That is a general statement, which lumps ALL OTHER TYPES into one category. AGMs use the exact same chargers as wet cell batteries. After all, they ARE lead acid batteries.
    Canada and the Alps
    Quote Originally Posted by EMSimon View Post
    Not quite; there are slight differences. But that isn't what matters.
    True, but what matters is that they cannot be overcharged and in the process of doing so, they cannot be topped up when necessary.
    I can overcharge my FLA every now and then to equalize the cells. And I can top them up as desired.
    My original FLA in my car will soon be in its 15th year operating under very wide temperature extremes (-30C to +34C).
    Vancouver, B.C. Canada
    Don't understand that sentence at all.
    Canada and the Alps
    Quote Originally Posted by happy wanderer View Post
    You do know that charge voltage is temperature and battery type dependent.
    You do know if you overcharge a battery, it gases...even an AGM.
    When it gases, it loses fluid.
    You cannot readily add fluid to an AGM.
    A FLA can be topped up. I take the one out of my car, clean it and top it up every two years. The voltage regulator within the alternator is spot on as well...the likely cause that the battery has lasted this long, plus the fact that it is a Panasonic car battery (only available in new cars). The last one in the other car was 18 years old when I lost track of it.
    mattituck new york
    there may be rust inside the fuel tank
    ntxt
    Yes, I know all those things.
    So I guess what you meant was "True, but what matters is that they CAN be overcharged and in the process of doing so, they cannot be topped up when necessary."
