nytrashman
i need to remove the rear shock on my 2007 R1200R and have run into a problem. i did not remove the rear tire, i just blocked up the final drive so it would not drop down, then removed both the top and bottom shock mount bolts and although the top of the shock is nice and loose the bottom is still held firmly in place. if i could get the bottom out the whole shock would come right out. what am i missing, or doing wrong ?
