Results 1 to 10 of 10
Thread: Speedometer / FD Compatible Numbers R60/5
Hybrid View
    Jun 2007
    Minneapolis, MN
    Hi Gang
    Wondering if there's an original owner in our community who can confirm if my Speedo is compatible with FD
    Speedo on my R60/5 is a bit optimistic. I recently had the instrument serviced but my resource forgot to ask for my FD number and the idea of providing it to him wasn't on my radar screen.
    W=1155 and # on FD is 37/11
    One other question: in the 60-70 mph range, the speedo needle "wags" just a bit - is this normal for this instrument? Tach needle is more stable - since instrument was serviced, was wondering if the speedo cable might be kaput.
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    Ken -
    Check Snowbum's site for gearing info. Most likely your cable is coming apart internally. You could try a graphite lubricant...if it helps, you'll know the answer.
    Pismo Beach, CA
    +1.
    Ken, immediately disconnect the cable at the transmission, or at the instrument. That's what Palo Alto Speedo recommended that I do when I mentioned my speedo was doing the same thing.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Jun 2007
    Minneapolis, MN
    Thanks, Guys
    Since I've got the U Joint issue to figure out, I'll furlough this one for awhile.
    Spoke to Mr. Henderson today who works on driveshafts - he says if the connectors are "V" shaped on top of the U Joints, they may be shot - will make sure drive shaft nuts are tight - they sure should be - will check.
    Will order a new cable - thanks as always!
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    It's supposed to be optimistic.
    It is by design optimistic.
    Attached Files Attached Files
    Registered User R100RTurbo's Avatar
    Jun 2013
    Abbotsford, BC Canada
    Not entirely sure on the inards of your speedo assembly, but mine displayed the characteristic jumpiness and cable checked out fine - but little nylon gearing within the speedometer head were not (and dry)
    I found replacement gear set on inward level from local shop and replace. The wear pattern on those was rather subtle, almost needed a mag glass to see the damage. I don't remember reading any other people's advice on lube service for those, but I have added to my routine long term list.
