Results 1 to 7 of 7
Thread: Illinois Toll Transponder Anomally
    I was required to get a new I-Pass transponder around the first of the year and did so. I used it on my truck with no problems, but when I put it on the R1200R to take a quick run today on the Indiana Toll Road, I got stuck at the entry point, as the system would not read the transponder. I made the exact same trip last week in my truck with no problems. I had used the old transponder on the R1200 before with no problems on the Indiana Toll Road, sticking it on the C-Baily windshield with Velcro. For today's run, I broke out the black Velcro and had at it. I mounted the transponder in the same spot, but the new transponder, being smaller, was totally covered with black Velcro when I was done. I know this is a stretch, but could the carbon black in the Velcro be shielding the transponder? Anyone got any other ideas?
    Registered User dmftoy1's Avatar
    Mar 2012
    Lexington, IL
    Ride around the barrier and let them match your plate to transponder manually?
    Fwiw I only use mine on the open road tolling and never even have it out of my hard bags. The tolls almost always show up on my account 5-7 days later.
    Oct 2007
    southwest Michigan
    I had this happen in my truck a couple of times using an old transponder. I think it just didn't get a good reading because the next booth it worked fine.
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    Maybe not applicable in your state, but around here, the transponders have DIP-switches that have to be set to correspond to the number of people in the vehicle. (In CA's infinite wisdom, a bike has to be set at "3"...!) Maybe some sensor at the entry booth saw a discrepancy between the transponder and the size or mass of the vehicle in the camera, and declared a "No Go"?
    Registered User GeorgeR1200RT's Avatar
    Jun 2006
    Ohio
    Illinois I-Pass transponders do not have a "dip switch". The transponder can be moved to any vehicle you have registered with them.
    I have used the I-Pass in Illinois, Indiana, Ohio, West Virginia, and other states with no problems.
    George
    R1200RT. Previous K1200RS, K1200LT, R80RT, R100R, R75/5
    Registered User Beemer01's Avatar
    Mar 2007
    Chicago, Ill
    Indiana Toll booths
    I've experienced the same #@$%* problem there. I've actually had to dismount the bike, remove the transponder from the top of my tank bag and wave it around under the sensor. Finally the lady came on the intercom and I had to read the serial number out to her (unmanned station natch) to get through.
    Never had this problem in Illinois.
    May 2008
    Evanston, IL
    The gizmos that read the transponders are mounted in the center of the toll lanes, and I found that if I had the bike on far left side of the lane sometimes my I-Pass wouldn't register. (Sometimes being where there is a gate, like the Skyway or in Indiana.) Being sure to ride down the center of the lane solved my problem.
