Results 1 to 12 of 12
Thread: 1990 K75s - tire recommendations ?
    Registered User jwetering's Avatar
    Aug 2011
    north vancouver
    I've had my K75s for two years now and have put 18K miles on it in that time. Mostly commuting, but lot's of short hops and burns around the town and on one or two day highway trips. I never ride two-up and usually ride with a few things in my side bags.
    The bike has had Battleax BT45 installed for the entire time and I've been through two sets now. I know I'm swimming against the stream here but I don't think I like them.
    In both cases the front tire was replaced because it was badly cupped, and that was the case with my first rear as well. The second rear tire just popped on me, leaving me stranded. It was worn down fairly well, but nowhere near corded. It's not clear yet why it popped, I haven't had a chance to take a close look yet. A brief look showed nothing extraordinary.
    Anyway - If I'm going to switch tires this is the time to do it. My third front tire is cupped again anyway.
    I'm thinking Metzler Lasertechs - but I'm quite open to suggestions.
    Thanks guys.
    jasper
    north vancouver
    1990 K75S
    Belton Tx
    I use Bridgestone Spitfires. I ran Battlaxes and found they handled well but wore fast. I then tried Metzler 88s and the wore well, but the front wobbled after a short time. The Spitires wear well and are smooth.
    Ron
    91 K75RT ABS
    Aug 2011
    north vancouver
    Thanks Ron;
    Is anyone using the Avon AM26 Roadrider?
    jasper
    north vancouver
    1990 K75S
    Jun 2010
    BC South Central Interior
    My four BMW's are now all running Michelin. I have used Metzler ME33/ME55 (lasertech) in the past on my K100RS with no problems as well. Just put a set of Pilot Activ on K100 wheels yesterday, getting ready to replace the previous Michelins that have about 18,000 kms. I have also used Bridgestones, Yokohamas and Avons on the K100RS in the past and haven't had any real problems with any of them. I have used Continental and Metzlers on my R1200GSA and liked the Continentals on the pavement but not so much in the gravel. The only serious problem that I have had with tires was with a set of Shinkos that I had on my R100GSPD. The rear tire started to delaminate at about 7000 kms. This was just after Shinko bought Yokohama's motorcycle tire business and was their first venture into dual sport tires. Generally I like the grip of the Michelins in the wet so I seem to be gravitating towards their product on all vehicles. It's hard to come to a firm conclusion as to "the best" because the manufacturers are constantly updating their product even though the name stays the same. I had three ME33's on my K100 in a row and first one outlasted two rears, the next one was worn out after one rear and the third one was done before the rear was to the wear bars. Each rear lasted about the same as the previous 16,000 to 18,000 kms. Since the Pilot Activ is a new tire I guess I will know if I like them in a few months and know how they wear in a year or so.
    2014 R1200GSA 33, 2008 HP2 Sport 10,000, 2008 R1200GSA 100,000 (Sold), 1990 R100GSPD 100,000, 1986 K100RS 152,000
    Jun 2007
    Minneapolis, MN
    I also agree that the BT45's wear faster than I'd like.
    Next set of tires for the K75s will probably be Michelin - just put a set on my wife's RX350 and I really like them. Used to run them on my Volvo 122s and really liked them.
    Michelin is a good brand and I've had good luck with their tires.
    I installed the BT45's about 5k ago, still original front tire in pretty decent shape. Have my second rear tire and it's starting to wear - I notice when the Battalax start to wear out, they wear out pretty quickly.
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    Feb 2009
    Mississauga, Ontario
    I'd recommend Michelin Pilot Activ.
    Walter
    H. L. Mencken
    Dances With Sheep GREGFEELER's Avatar
    Boise, ID
    Quote Originally Posted by jwetering View Post
    Thanks guys.
    I love the BT45's. I have a set on one of my K75s, and they compare very favorably to the Dunlop radials on my K75S. I ride both bikes very aggressively and find the BT45 the best handling bias ply tire I've ever used. I'm on my second BT45 rear and the same front, and they are wearing perfectly. What kind of tire pressures are you running vs. the book listings?
    However, there are a lot of good tires now, and many will last longer (although cost more) than the BT45s.
    Greg Feeler
    BMW MOA Director & Ambassador
    1972 R75/5, 1990 K75, 1990 K1, 1992 K75S, 2003 K1200RS
    13278
    Lynchburg, VA
    K75s tire recommendations
    Went to AM26 RoadRider Avons after THIRD Metzeler ME 88 had splits down in the lowest part of the treads. Last one was w/ less than 2,500 mi. Metzeler denied replacement. No more Metzelers for me. Pity too, because they used to be good tires. Germans never admit their mistakes. On a new set of Avons touring at the moment. Last tire was an AM26 RoadRider was 9,262 mi. on a rear. Two up and loaded 40% of time. Cupped on the sides, which was a first for me on the rear. Acceptable tire for me at $135 for a rear and $115 for a front. Charlie
    SW Ohio
    went through lots of lazartecs, good tire but the blocks wear faster on the backside. Decide to try Spitfires because I could get them amazingly cheap. Pleasantly surprised by how good they are, though I only have a couple thousand on 'em
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    PeteG
    Dec 2009
    Woodacre, California
    Angry
    Hi Jasper,
    I too am a dedicated Spitfire tire user. I've gone through five sets and they are adequate for my riding habits. I've tried the BT45's and they do handle better. If handling is your priority then you can't go wrong with the BT45. Spitfires will last longer and do not cup (the BT's did on my K75C). I haven't had a problem with the Spitfires in rain, but again I ride pretty cautiously.
    My mileage range for the Spitfire is 7K to 10K.
    Pete
    Jun 2008
    Canyon, TX.
    I like the Michelin Pilot Activ. I ride rather gently so ultimate handling is not my big concern. I am more interested in mileage. I hate changing tires. My rear Michelin went 10,000 before I changed it. My front has 14,000 on it and will probably go another 1,000. The wear pattern on the front is very good with almost no cupping. Still handles well with no front shake like the Continental Conti Go did. I mount and balance my own tires and the Michelins can be difficult to get the beads seated on the rim. Lots of good tire lube and a little more air pressure than it would normally take.
    Aug 2011
    north vancouver
    Thanks for all of the suggestion gents. I ended up buying an Avon AM26 Roadrider because of price and availability.
    We'll see how it goes.
    jasper
    north vancouver
    1990 K75S
