Results 1 to 15 of 18
Thread: Tarnished Reflector on R75/5
    Apr 2012
    Los Angeles, CA
    Hi all,
    Was replacing the rubber gasket and spring clips on my headlamp today (as well as cleaning the glass) and I noticed that my reflector is starting to tarnish. Is there any-way to clean the reflector? It appears to be a metal reflector, rather than the plastic version that Hucky sells.
    If its not cleanable, what would be the proper way to restore this? ie, having the chrome/mirror finish replated?
    Cheers,
    Jonathan
    Jun 2007
    Minneapolis, MN
    Maybe gently try 3M rubbing compound or look for a used one in good shape online.
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Jonathan,
    I don't know a way to clean the layer of reflector material. The layer is very thin, and any abrasive (even a relatively mild one, such as rubbing compound) will quickly rub right through it.
    I think you have to replace it, either with a good used one or with a more modern one, such as on the R65.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Sep 2004
    Arlington, TX
    Reflector
    Correct on the thin layer going away quickly! If you choose to get a modern, H-4 reflector for an R65, then you also need to get the lens as well. The /5 lens works with the incandescent bulb, but not well with the halogen bulb.
    Boxerbruce
    Snowbum mentions using some alcohol mixed with a small amount of detergent and in some water, and using appropriate lint-free cloth, and then flushing with clear water. Not sure this will help with "tarnished" but should help with "dirty".
    Not sure about this one, but on other items I sometimes try a little toothpaste first as it is very mildly abrasive. Try in spot where it won't damage anything good.
    Apr 2012
    Los Angeles, CA
    Quote Originally Posted by 1074 View Post
    I already have an h4 kid/bulb/lens. (Says h4 on the lens).
    I'm not sure if it's from a /5 or if it's from an r65. Is there an easy way to tell?
    Apr 2012
    Los Angeles, CA
    Is this the proper reflector?
    http://www.ebay.com/itm/BMW-New-Bosc...30983958557%26
    Mine looks similar (albeit tarnishing/de-silvering) minus the extra cap/shroud over the headlamp bulb.
    Not sure if these will work or not.
    Pismo Beach, CA
    No, that is not the correct reflector. It is described as having an 8" diameter (/6 and later)
    The /5 reflector is 160mm diameter.
    63 12 1 351 652 is the correct p/n for the /5 reflector.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Pismo Beach, CA
    p.s. I'd use Simichrome, if it doesn't work, nothing will.
    Lew Morris
    1963 Dnepr
    Apr 2012
    Los Angeles, CA
    Quote Originally Posted by lmo1131 View Post
    Looking at photos of that reflector, it doesnt match the look of mine at all. I have the h4 kit already installed (the headlight lens says H4 on it and the reflector looks mostly identicle to the one above minus lamp shroud that protrudes).
    I guess Ill have to keep looking then.
    Monza Blue 1974 R90/6
    Delaware
    I second and third the advice about being very careful cleaning the "reflective" layer. It comes off really easily. Whatever you decide to try, go easy and stop after the first few seconds just to make sure you aren't cleaning by removing.
    Barron
    Apr 2012
    Los Angeles, CA
    Quote Originally Posted by barron_williams View Post
    Barron
    I think i am just going to have to find a newer one.
    Anyone know if the ones from hucky are (if bought separately) Bosch versions? His price is pretty expensive. Like 220 dollars.
    Pismo Beach, CA
    I can't say for sure, you had better call him first.
    FROM MY PERSONAL EXPERIENCE ... if you order that part, and it does not fit properly, HE WILL NOT ACCEPT A RETURN. It's considered, by Hans, to be an "electrical part" and will not be "returned".
    I bought the "cheap" H4 conversion kit, not knowing it had a plastic reflector. I requested a return and was denied based on his "no return of electrical parts" policy. I even suggested that I purchase another H4 bulb that he could sell with the "returned" reflector. No deal.
    CAVEAT EMPTOR!
    Lew Morris
    1963 Dnepr
    replate
    Wait till this winter and then have it re-silvered.
