Results 16 to 24 of 24
Thread: Loss of power 100s
    Old Salt MEAirhd's Avatar
    Apr 2013
    UptaCamp
    I had a condenser "POOCH" a few day's ago with about 1500mi of duty. Similar problems, could not figure out the root of the problem till my mechanic narrowed it down. I should have left the old one in there. Do we really know where these parts are made today?? I don't remember having to change condenser's but every few years.
    Colorado Springs, CO
    If it is a 100 with emission stuff it does vent from underneath the seal lip of the tank cap via a solenoid into the air filter housing.
    Is that what you had in mind, bikerfish?
    /Guenther
    Bike in question is a 1978 model:
    http://forums.bmwmoa.org/showthread....l=1#post887391
    [QUOTE=jimmylee;887803]I didn't get, but are you still running points and condenser or electronic.
    What you are describing sound eerily similar (if I remember that far back) to what my /2 did. Turned out to be condenser.
    Ran fine until it started cutting out, plug wires tested bad are coming from BMW, condenser, points are being changed also. The wires are shot condenser & points may be at fault also so.
    I was interested in a pre can ignition bike chance I took seller had basically not done anything! Go figure.
    Just trying to git it home so I can go through it all.
    Thanks for the input, thoughts!
    I believe this is a pre emission stuff 78s has only a single vent to r side carb, if that is correct?
    Quote Originally Posted by seaswood View Post
    Yes it is a single vent from the breather to the right carb. The '78s (most of them anyway) are subject to EPA (aka emissions) constraints but maybe not in the way you're suggesting. No fuel vent lines or solenoids, no external pipes back to the heads, etc. The timing on the '78s were set back in order to make them run a bit leaner...it got worse over time.
    S
    Would the Smodel had a oil cooler? & a S fairing?
    I know the RS had a oil cooler, did the S?
    Has the frame for it to fit
    Only a few RS's came with oil coolers in '78, & none of the S models to my knowledge. Could have been added by dealer, but not too likely.
    why do you ask?
    why do you ask?
    Just curious as where what was original to this bike, thanks.
    http://www.omnilex.com/public/bmw78/
