Results 1 to 3 of 3
Thread: Fork oil change - '87 K100RS
    Dec 2012
    Procedure for changing fork oil in a 1987 K100RS. Anything of note? Is it simply a drain (drain plug) and fill?
    How much oil in each leg?
    Thanks.
    IBMWR K-tech is usually my first stop for things like this:
    http://www.ibmwr.org/ktech/change-fork-oil.shtml
    Ted
    1994 K75RT
    Moto Pages
    SW Ohio
    from the IBMWR page:
    The only things I'd like to add .... is that those screws at the bottom of the fork (drain plugs) should be installed with great care and MINIMAL torque.
    Let me repeat:
    The only things I'd like to add .... is that those screws at the bottom of the fork should be installed with great care and MINIMAL torque.
    Really cannot stress this enough!
    I think you can strip them by finger tightening!
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
