Results 1 to 15 of 25
Thread: Bringing a 2007 R1200RT-P back to life
    Mar 2013
    Walnut Creek, CA
    Looks like I'm getting a bike at auction. 07 RTP, just under 18k miles, has been sitting for close to 3 years.
    It needs a battery for sure, then I have two choices.
    a) bring a battery, ride it home, do some work myself on it
    b) have it towed to the local dealer, let them sort it ($$$)
    I believe but am not positive that the 07 should have the non-servo brakes and a brake fluid flush is a standard process (I'm really puzzled by the tech article that shows compressing the brake calipers with C-clamps to remove fluid - this seems unnecessary and dumb).
    Anything else you would check?
    Nov 2007
    Quote Originally Posted by danix View Post
    3 year old tires will likely have a hard slick coating on them. .You might want new. At least put on a new oil filter before you ride, sitting in oil for 3 years, some brands may come apart. Doubt if an BMW one would , but aftermarket who knows.
    Compressing the brake calipers like shown minimizes the fluid in them for the bleed, you get a higher percent of new fluid. Just sitting inside should not have much moisture in the brakes, if it was outside that would be first thing I did.
    Learning to do the work yourself is a reward.
    Rod
    May 2006
    Northern New Jersey
    What is the bike's history? Was it a civilian purchase originally? I can't see how a RT-P that saw service duty has such low miles.
    Check it over thoroughly, at the least, change ALL fluids and the tires.
    Here in the East, a couple years ago a few cities auctioned off low mileage RT-Ps because they were caught in floods where they were stored. If there's any electrical or electronic issues (other than a battery) - run, don't walk, away. Be careful at auctions.
    Mar 2013
    Walnut Creek, CA
    The bike was a former Sacramento County Sheriff unit. Due to the recession, their bikes got mothballed in 2010 and haven't run since.
    They are now putting a few back in service and auctioning off the rest. I verified history with the local dealer (A&S)
    Registered User ajaxthegreater's Avatar
    Jun 2013
    Highlands Ranch, CO
    Fuel
    I would be most concerned about the fuel lines, injectors, etc. I don't know if these were drained or maybe a stabilizer was added, but even so is that good for 5-6 years? Gas can turn to shellac. Probably will need a good inspection and lots of cleaning/cleaner.
    Bill in Highlands Ranch, CO
    2012 R1200RT and some other older junk
    Still plays with trains. tinytrains's Avatar
    Oct 2009
    Torrance CA
    If the department mothballed them properly, they may start with a battery and gas. If not, Plan on new injectors and probably a fuel pump. My dealer will not touch a bike that has been sitting over a year. They say in most cases the cost is not worth it.
    1988 K75 Low Seat
    2009 R1200R Roadster
    Mar 2013
    Walnut Creek, CA
    We'll see. The facility guy told me that several people have just showed up with a battery and ridden away. I'm going the conservative route and having it transported to A&S.
    Jun 2013
    Highlands Ranch, CO
    I'd do what you propose
    Back to your original question, I'd bring a battery and some gas and try to start it just to see what happens. Whether oil and other lubricants sit in a can or a sump for 5 years will probably not make a giant difference as far as the long term life of the bike. If you can start it and get it to run decently you are probably 90% or more good to go.
    May 2006
    Northern New Jersey
    Quote Originally Posted by TinyTrains View Post
    Really?
    Yes, I agree if the bike's book value is only $500. But if that's really their general policy, I wouldn't trust them for anything.
    May 2006
    Northern New Jersey
    Good choice. It's not like you gotta get it on the road immediately.
    Before you commit to having A&S do a lot of work to it, if A&S was the dealer Sacramento Sheriff dept used, they would have all their records of what they have done to it. Ask them to print out a report. I know it's only 18K miles but what you'd be looking for is a recurring problem of some kind. And even though you wouldn't think so, 18K is enough miles for the bike to need a clutch, especially if the officers came to BMW from Harley or if they beat the heck out of their motors. But since it's only at 18K, I wouldn't worry too much.
    BinkleyLane binkleylane's Avatar
    Jul 2012
    Springboro, OH
    Good for You! If I may ask, what (ballpark) was the auction price. I have thought about a "project bike" and a RT-P sounds like a good start.
    Bob
    B-est M-otorcycle (in the) W-orld
    Have Bike - Will Ride
    Mar 2013
    Walnut Creek, CA
    Already checked the full history with A&S, nothing remarkable, just normal service and one recall. New tires at 17k, bike only has 18500 miles or so now.
    I got the bike for $6001 plus auction fees, so $6600.
    There are several more RTPs from Sacramento and a few from Brea (also in CA). Recent sales for bikes with 50k miles or so were in the high 5000s so I think $6000 for a 18k mile bike is a great deal.
    The website is publicsurplus.com if you want to browse.
    For example here is a 2008 with 39k miles coming up in Brea - has new clutch and transmission (frankly not sure if that's a good or bad sign):http://www.publicsurplus.com/sms/auc...iew?auc=938976
    Registered User natrab's Avatar
    Sep 2012
    Oakley, CA
    I would change all the fluids in it. Easy to do yourself. I just order the parts from beemerboneyard. If you need help and can get the bike down to San Jose, I'd be happy to help.
    2013 R1200RT 90th - "Tyr" - 65k - Purchased 12/13/2013 brand new!
    2011 R1200RT-P - "Ursula" - 18k - Purchased on 1/30/2016 at 13k miles
    2007 R1200S - "Sexy Beast" - 28k - sold
    2006 R1200RT "Wōden" - 84k - sold
    Mar 2013
    Walnut Creek, CA
    Thanks natrab, may take you up on that offer. Payment is going to take 48 hours so looks like nothing is happening today anyway, gives me more time to figure out what I want to do.
    May 2006
    Northern New Jersey
    I would have to agree that you did get a great deal. Change the fluids, do a safety check while changing the fluids, and ride away! Good luck with it, and many safe miles!
