Results 16 to 17 of 17
Thread: Deep oil pans for '70's airheads?
    May 2012
    VA
    How much oil volume did this add? 1 Qt? Less than 1 Qt? Also, did these parts also lower your oil pick up suction screen down an equal amount as the new depth of the pan?
    What I am wanting is a "buffer" just to make sure that I NEVER go low on oil, and the added benefit of cooler oil.
    From what I have read - I have not measured the change in oil quantity yet - the increase in oil volume is 250 ml. That is when using the stock /7 dipstick and the oil level at the same 'max' location. While this is some extra oil (~ 8 oz), I mainly installed the deeper (BMW) oil pan for the baffle.
    Here are several other options:
    http://www.bmw2valve.com/motorcycle/B/1113100.html
    http://www.bmw2valve.com/motorcycle/B/1113110.html
    http://www.bmw2valve.com/motorcycle/B/1113120.html
    http://www.motoren-israel.com/index....nce-rings.html
    p.s. The hex bolts listed previously are for the deeper pickup. The 81+ screen was slightly different than my 1978 /7 screen.
    Stan
    AH# 13238
    Jun 2007
    Portsmouth, NH
    Wunderlich sells deep sump kits for airheads.
