Results 1 to 10 of 10
Thread: First tour in five years
    Registered User cowchip's Avatar
    Nov 2011
    Mar Vista
    I have a question for the experts out there in regards to travel tips. I am heading out to Salem for the Rally in a few weeks. This will be my first Rally and first tour in five years. I never thought too much about taking a tire repair kit with me but since I have a small air pump I should probably think about getting a tire puncture kit for motorcycles. I have previously traveled to Colorado and across country without taking anything but feel that my luck might wear out. I am on a new low miles 2011 RT1200RT.
    I will be traveling up HWY 1 from Los Angeles starting Sunday, July 14.
    My travel blog: motorcycledon.blogspot.com
    Don
    2011 R1200RT
    Mar Vista, CA
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    I carry a sticky rope kit which you can buy at Walmart for $6. I even carry it on day trips along with an electric pump.
    Lee
    2016 R1200RS
    MOA # 30878
    Ed Kilner #176066
    Nov 2011
    Mississauga, ON
    I use a kit from these folks
    http://www.tirerepairkit.com/default.htm
    Can't say these are the best since I have never needed to plug a tire yet - but I dealt with these folks last year and found them to be very good to deal with.
    Ed
    2015 R1200RT; 2011 R1200RT RIP; 2000 Triumph 900 (sold)
    http://triumphantsblog.blogspot.ca/
    R1200RT Artiee's Avatar
    Jul 2008
    Northern Virginia
    Slime pump
    http://www.motorcycle-superstore.com...-Inflator.aspx
    Stop-n-Go Plug Kit
    http://www.stopngo.com/products/Pock...ess-Tires.html
    I carry them in the empty space below the rear seat, tucked back under the cargo deck. The space isn't water tight so place the pump and accessories in Ziploc plastic bags for protection.
    Experience IS NOT the best teacher! Someone else's experience is the best teacher.
    Registered User David13's Avatar
    Nov 2011
    Lomita, California
    I carry something similar.
    The only time in memorable memory (the years I can remember) when I did have a nail and low tire condition according to the tpm, I happened to come to a stop ... directly in front of a tire shop.
    So I paid $7 for a worm patch and some air.
    And put at least another 1000 miles on the tire before replacing it.
    dc
    Polarbear Polarbear's Avatar
    Clovis,CA
    My Last;
    Leaving Bloomsburg, PA. Rally, even before getting off the grounds, I picked up a nail. Rear tire. I used the above snake, as I always have and got home, no issues. Home was 3500 miles. I've never had one fail me, after maybe 6 or 7 flats using sticky tire snakes you can buy everywhere. I do not think its recommended, however, to keep the tire in use without at least getting to a bike shop, removing the tire and a good look see for internal damage. I have never done that, but in fairness mention it for safety concerns one may have. The snakes work well. Other brands probably equally so, as in mushroom plugs and the like, non of which I have experience using. Randy
    Clovis,CA
    Btw:)
    My Toyota Pickup just got a nail! I plugged it about two weeks ago and no air loss in 500 miles. Randy
    Nov 2011
    Mar Vista
    Thanks for suggestions
    Thanks to everyone who made suggestions. I purchased a Dynaplug kit. I hope I never have the chance to try it out.
    Made my list and I am ready to pack and head to my first rally.
    Don
    2011 R1200RT
    Mar Vista, CA
    Oct 2011
    Ohio
    Quote Originally Posted by BMW Triumphant View Post
    I have had the same experience with these folks. It is a nice kit and in a reusable sealed tube. I have had "worms" dry out and become unusable just sitting in a toolbox drawer. That's why I like the sealed tube on this kit. I do take a look at it once or twice a year just to be safe.
    Jeff
    93 K1100LT
    03 K1200GT gone but not forgotten
    14 Victory Crossroads
    rsbeemer 22600's Avatar
    Jan 2011
    New Braunfels,Texas/Taichung, Taiwan
    +1 on the Dynaplug ket
    Quote Originally Posted by cowchip View Post
    I've used them many times on my truck tires and they hold; I've never had a leak at a plug. One thing I did do was take a old small shaft phillips screw driver and grind it down to a sharp point. I used it to ream out the hole or make the hole more open where the plug will go through. The tool needs to be stronger than the one that come with the kit. Without it , pushing the plug through was almost or very difficult. Put some of the glue that comes with the kit on the shaft when you work it through, that will give you a better seal when you put the plug in. A little 12v pump will come in handy also.
    DW
    1978 R100rs MOA#22600 125cc Kymco , 180cc Kymco Racing King
    The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails.
